TPI Conversion Fuel Pump Questions
Old Sep 30, 2004 | 10:54 PM
Jasonty's Avatar
Jasonty
Default TPI Conversion Fuel Pump Questions
Hey folks, got all the stuff for my TPI/LT1 conversion except for the fuel pump... Trying to decide which one to get.... I'm looking at this one on Summit... Tell me what you guys think. http://store.summitracing.com/defaul...25239&x=17&y=8
It's an external inline Vortech unit, max 40gph/155lph, 90psi... I'm thinking I need a pump that flows more then that, but I can't find a good one. Anybody have any ideas??? I think I want at least a 60gph/220lph fuel pump with at least 45psi...
Old Sep 30, 2004 | 11:17 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I used a 82 sending unit with 90's LT1 pump and it worked great with the tpi. Still working with the LS1 also.
Old Oct 1, 2004 | 08:02 AM
Jasonty's Avatar
Jasonty
Did the 82 sending unit and 90's LT1 pump fit together? Also, did this setup fit in your stock tank?
Old Oct 1, 2004 | 08:05 AM
Twin_Turbo's Avatar
Twin_Turbo
Yea, easy as 1..2..3. we do this swa on CFI's all the time when the original pumps crap out
Old Oct 1, 2004 | 08:18 AM
comp's Avatar
comp
Old Oct 1, 2004 | 08:51 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
Yes to all, the only change will be to the hose size and adding a connector and tail to the pump. The newer pump has a different electrical pulg than the 82. You will spend more time attaching hoses to the sending unit.
Also, there is no pump noise at all.
To TPI Conversion Fuel Pump Questions
