Arch, Gas, or MIG?
Old Oct 1, 2004 | 11:56 AM
GnDn's Avatar
GnDn
Default Arch, Gas, or MIG?
I am going to need a welder for my 81 restore project and need help determining what the best welder to use would be.
First question, which welder is te most cost effective?
Second question, which welder is prefered to use?
Old Oct 1, 2004 | 12:03 PM
Twin_Turbo's Avatar
Twin_Turbo
MIG is by far the most versatile, TIG makes cleaner welds but it's really slow. Stick just plain sucks. If you want the best compromise between clean welds, being able to lay a nice clean weld without a lot of practice then the MIG is the best. Do get one with a gas hookup, flux core is ugly.
Old Oct 1, 2004 | 12:07 PM
lars's Avatar
lars
For general home use and restoration work, you want to use a MIG (GMAW) welder (wire feed) with shielding gas (not flux core wore). You don't want to use oxy-acetylene ("gas") or stick (SMAW). However, if your wallet can afford it, nothing beats a TIG (GTAW) setup for quality welds, but a mig will do what you need done for Vette work. Lincoln makes some very good home-use MIG systems, and they come complete with setup instructions for the first-time user.
Old Oct 1, 2004 | 12:19 PM
Pete76Shark's Avatar
Pete76Shark
For shielding gas I use 75% argon and 25% co2, I think this is pretty much standard.
I have the smallest HOBART 220volt they sell and it is the best money I spent.
Old Oct 1, 2004 | 01:16 PM
comp's Avatar
comp
nice to have a torch for somethings
Old Oct 1, 2004 | 01:43 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
i have all three and by far the best is the mig for all around use, although i use the shielded inner core wire, my unit is a lincoln and they sell similar ones at Home Depot in the $350-400 range, the home owner version of the Lincoln MIG welders allow you to use either the iinercore wire or to upgrade to using the gas. i started with the inner core wire and have never been motivated or felt the need to step up to the Gas conversion. however you definetly should get two electric 4 or
4 1/2 grinders and set one up with a cupped wire brush and the other with a grindwheel. and if you have never welded before the new facemasks that automatically darken are also nice.
Old Oct 1, 2004 | 01:53 PM
stpman's Avatar
stpman
Once you make the switch you'll wish you did it sooner, I used innershield once and only because I was welding outside..............swore then if I could avoid it I would never use inner shield again. It's sooooooooo much nicer with gas.
I have a stick machine, a tig setup for doing mild and Stainless steels as well as a couple of migs setups. I use the mig (with 75/25 mix gas) for most of what I do.
Steve
Old Oct 1, 2004 | 01:55 PM
Z-man's Avatar
Z-man
I'm looking at these also. Can you get a good one for home use that runs on 110 or do I need to run 220?
Old Oct 1, 2004 | 01:58 PM
lars's Avatar
lars
Although the 220 machines offer greater capability, you can get good 110 units that are adequate for home use/automotive restoration stuff. Most of the 110 mig machines are good for up to 1/4" steel, althouh that's pushing it to the limit. You seldom do more than 1/8" on auto frames & components, so the 110 machines work fine.
Old Oct 1, 2004 | 02:03 PM
stpman's Avatar
stpman
I have a 110 volt MIG that I bought used for $50 (needed a diode replaced) and found that it was great for up to 1/8" steel.
The only problem you would run into is the duty cycle of these machines, 20% duty cycle is 2 minutes welding & 8 minutes waiting.
Old Oct 1, 2004 | 02:04 PM
bobs77vet's Avatar
bobs77vet
mine is a 110volt lincoln weld pak 110 or 125 something like that and its comparable models are at Home depot and lowes
Old Oct 1, 2004 | 02:21 PM
PureSilver's Avatar
PureSilver
Northern Tools has the best deal on the 110 volt MIG Hobarts with the gas set-up; it's about $470. Of course, you need the cylinder, helmet, etc., so add that in before telling your wife...
As for duty cycle, I try never to work so fast that I miss something, and the breaks help.
Old Oct 1, 2004 | 02:49 PM
norvalwilhelm's Avatar
norvalwilhelm
I agree with every word Twin Turbo said but he didn't go far enought. Spend the extra money and only go 220V . The advantage of 220 over 110 is you can crank the wire feed rate up to flow the weld in. I use my 220 unit on thin material but I always seem to have the power and wire feed cranked right up. The faster you pour the weld in the less heat put into the metal. Burn it is fast but also deep. Besides who knows when you start building suspension parts and need the extra bit for the heavy steel and multiple passes.
Old Oct 1, 2004 | 03:06 PM
Twin_Turbo's Avatar
Twin_Turbo
oh yah you guys have 110... I'd want 220 as a minimum also, mine is a 400V unit...finally we have something bigger & better
Old Oct 1, 2004 | 03:09 PM
Pete76Shark
Old Oct 1, 2004 | 03:13 PM
Gordonm's Avatar
Gordonm
A 220 volt plug is not very hard to wire up. If you aregoing to spend the money I would go with the 220. If you are not confortible wiring up a 220 circuit get pro to wire it up for you. I have wired many 220 circuits and it is not a big deal. My breaker box is in the garage so access is very easy.
A 220 mig welder is all the homeowner will ever need.
Old Oct 1, 2004 | 03:16 PM
NHvette's Avatar
NHvette
My experiences are very good with the 130 Amp (110V) unit
that I bought. Here is a link ... $270 for the welder ... add on for
gas regulator and tank (get tank at the local gas dealer).
Here is a link to my welder ... they also have an 180 Amp (220V)
model for $60 more.
http://store.weldingdepot.com/cgi/we...ml?id=J4dYdE7C
To Arch, Gas, or MIG?
