Fuel delivery
Oct 1, 2004 | 03:15 PM
St. Jude Donor '05
First C3 General Poster!
Fuel delivery
Hey all,
For you big horse guys, what is your fuel delivery system like? GPH on the fuel pumps, manual or electric, regulated or not? This is going on a Holley carb btw (not the 4500 series).
Oct 1, 2004 | 03:26 PM
Oct 1, 2004 | 03:45 PM
St. Jude Donor '05
Quote:
Originally Posted by comp
whats your combo.????
As in components of the carb/intake?? Or....??
Oct 1, 2004 | 03:47 PM
What do you consider "big horse"?
Oct 1, 2004 | 03:51 PM
St. Jude Donor '05
I thought youd never ask
It will be between 530-575 horses and between 540-585 pound ft of torque
Oct 1, 2004 | 04:19 PM
I have:
SX-18203 fuel pump
SX-41002 fuel filter
aeromotive a2000 regulator
-10 into 2 -8 into 4-6 an lines.
Oct 1, 2004 | 04:27 PM
St. Jude Donor '05
Pretty intense little system there hahaha is that much necessary or is that just playing it safe?
Would mating up a say, 140gph free flow 14psi max Holley electric fuel pump make sense considering it is a Holley carb? More or less gph here for the 500+ hp?
Oct 1, 2004 | 04:30 PM
playing it safe
Oct 1, 2004 | 04:32 PM
St. Jude Donor '05
check my edit...
for your help though
Oct 1, 2004 | 04:52 PM
What's your power goal? calculate the fuel requirement and select a pump that will deliver it (with margin built in), some guys use 2 pumps.
Oct 1, 2004 | 04:56 PM
Jeez, how did that L88 ever manage to race?
Oct 1, 2004 | 05:30 PM
St. Jude Donor '05
Quote:
On an 870cfm carb, Im taking a wild guess that 140gph of fuel should be enough? Whats the formula to calculate this?
Oct 1, 2004 | 07:28 PM
St. Jude Donor '05
bump
Oct 1, 2004 | 09:30 PM
You'd think a 140 gallon per hour fuel pump would be sufficient. The early C3's had 20 gallon fuel tanks. A 140 GPH pump will empty the tank in about 8 minutes and 35 seconds!
Oct 1, 2004 | 09:31 PM
St. Jude Donor '05
Quote:
Originally Posted by 68/70Vette
You'd think a 140 gallon per hour fuel pump would be sufficient. The early C3's had 20 goallon fuel tanks. A 140 GPH pump will empty the tank in about 8 minutes and 35 seconds!
ummmmmmm
Oct 1, 2004 | 09:37 PM
Quote:
They do just fine on a stock pump and carb.
Oct 1, 2004 | 09:49 PM
St. Jude Donor '05
Im still wondering what was meant by the 8 minute remark? He surely isnt insinuating that a 140 gph fuel pump is going to drain my tank every 8 minutes when Im driving...because...
Oct 1, 2004 | 10:31 PM
Quote:
I know... Just being a smart-***.
Oct 1, 2004 | 10:54 PM
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Nothing fancy a Carter mechanical "super street" pump M6900 is what I have and it flows 120GPH at 6 psi.and hasn't let me down 60 bucks at Jegs
Oct 1, 2004 | 10:58 PM
I use a Holley 12-454-13 with a regulator at 8psi
and a Race Demon 975.
.....think I need more gas
