According to the Compcams solid lifter cam install instructions, they say to adjust lash per the cam card for cam break-in, which is .016 on int and exh. It goes on to say that after break-in, the engine will be at operating temp and that due to thermal expansion, the lash will now be looser than it was when the engine was cold.
Now, that just doesn't sound right to me. I would think the lash would be tighter due to thermal expansion. According to what I've read here, you should adjust the lash .002 looser (in this case, to .018) when cold and the lash should be real close when warm.
Are the instructions screwy? Should I adjust lash to .018 with the intent of heat getting the lash to the .016 target?
The lash will increase (loosen up) as the motor reaches operating temp. When I have to set the valves cold I always go .002 tighter with a iron head / iron block, .003 with an alum head / iron bock and .006 for an alum head / alum block.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Just a general guideline from Crane Cams website
Iron block, iron heads ADD + 0.002"
Iron block, aluminum heads SUBTRACT- 0.006"
Aluminum heads, aluminum block SUBTRACT-0.012"
I have been experimenting with my solid roller and whle it is best to set them hot I set them cold last time and set them - 0.002" ) iron block, aluminum heads ) I will take a valve cover off tommorrow when hot and see what they read.
Brett:
As the motor increases in temperature the hottest parts will increase in size the most. The block and heads are where the combustion takes place so that will be the hottest part of the engine. As the block expands, the deck surface is moved away from the cam centerline. As the heads expand, the rocker studs are moved away from the cam centerline. As both of these parts expand the distant from the cam centerline to the rocker arm increases, causing an increase in vavle lash. The pushrod and lifter are isolated from the combustion temperature so they do not expand as much as the block and heads. With alum heads or block, the aluminum expands at a greater rate than the steel push rod and lifter so they will increase the lash more than an iron head / block combination.
Brett:
Brett:
Ya know, I've always been partial to cork too. I have cork on my valve covers now. However, the cam change gasket set (Fel-Pro) I got from Summit has rubber ones in it. Dunno how I'm gonna like that...
