Need help finding a choke
Old Oct 4, 2004 | 08:42 AM
Xakk's Avatar
Xakk
Default Need help finding a choke
Ok, so the 81 had an Edelbrock Performer intake (2101 I maybe?) and a worn out 650 Holley when I bought it. We took off the Holley and replaced it with a Q-jet from O'Reilly's for the time being. The problem is, we can't find a choke that'll fit the intake. Anyone have any suggestions or part numbers?
Please? Anyone?
-Xakk
Old Oct 4, 2004 | 09:19 AM
Paul L's Avatar
Paul L
For a temporary solution I would suggest you use a manual choke.
Old Oct 4, 2004 | 10:40 AM
SLine78's Avatar
SLine78
You should be able to use Edelbrock's divorced choke kit (#1931) for small block performer manifolds with that carb and intake.
Mike
Old Oct 4, 2004 | 01:41 PM
PRNDL's Avatar
PRNDL
Mike
Stock stuff doesn't fit on the Edelbrock intake. How convenient!
Old Oct 4, 2004 | 02:28 PM
Xakk's Avatar
Xakk
Mike
Thanks Mike I've been going nuts trying to find a choke that'd bolt up to this intake. The parts stores didn't even show a listing for it, and NOTHING fit that bolt pattern. Running without a choke isn't so bad right now that it's warm, but it's gonna blow when it starts getting colder. Hopefully this'll fix it.
-Xakk
Old Oct 4, 2004 | 04:16 PM
SLine78's Avatar
SLine78
Xakk,
I was l;ooking at your photos again, and was wondering if your choke pull-off is connected? I don't see a vacuum hose going to it, and it looks like there is an open vacuum port just above the fuel inlet.
Mike
Old Oct 4, 2004 | 04:21 PM
Xakk's Avatar
Xakk
Xakk,
Mike
Huh. You may be right. I'll have to go take a closer look.
-Xakk
Old Oct 5, 2004 | 10:23 AM
Xakk's Avatar
Xakk
Well hell. Ordered a 1931 choke from Edelbrok and it still won't fit. That damned offset bolt patern on the intake is making this a serious PITA
-Xakk
Old Oct 5, 2004 | 12:29 PM
LemansBlue68's Avatar
LemansBlue68
Have you tried calling Edelbrock directly? Perhaps their tech people could help. Personally, I would look into an electric choke. That way it is totally independent of the intake manifold so no hassles with getting linkages correct and lined up. A number of Q-jets were fitted with electric chokes from the factory. I'm sure there is a setup out there that is a bolt on. The electric chokes are easily adjusted as well.
Send Lars a note as well. I'll bet he has some info on a conversion.
Old Oct 5, 2004 | 01:58 PM
SLine78's Avatar
SLine78
Doesn't it sit on top of that existing plate?
Take a look at the picture here of the choke kit installed on the manifold
http://www.edelbrock.com/automotive/...et_access.html
Mike
Old Oct 5, 2004 | 03:46 PM
Xakk's Avatar
Xakk
It should sit down on the plate, but the 1931 bolts straight down the center (|). The bolt holes on my intake are in opposite corners from each other (\).
-Xakk
Old Oct 5, 2004 | 05:03 PM
SLine78's Avatar
SLine78
Xakk,
Let me try again. You do not remove the existing cover held down by the opposite corner capscrews. It remains in place and the choke sits on top of it with the coil running front to back not left to right like the cover. There is a small screw hole by the right cover capscrew where a screw is inserted through the coil bottom into hole to secure the coil to the cover.
This picture shows how the choke sits on top of cover and is secured by a screw into the cover.
Old Oct 5, 2004 | 11:00 PM
DaveL82's Avatar
DaveL82
SLine is correct. The pad you have on the intake takes one screw to mount the thermal spring and the dimple is used to align a mounting pin. The same choke is sued on my 1976 4x4 blazer.
A real auto parts house can get you the choke kit or try the ZIP catalog.
The choke will consist of the thermal spring shown in the pic above, a metal cover to retain the heat for hot restarts and the rod that goes up to the choke linkage on the carb. The only issue might be getting a link from the thermal spring to the linkage of the correct length. Worse might be to make one which I have done in the past from a rod and then file slots for two e-rings at each end.
Dave
Old Oct 6, 2004 | 08:01 AM
Xakk's Avatar
Xakk
Ahh. I see what you guys are talking about now. That makes a lot more sense. I honestly didn't remember seeing that bolt hole on the plate. Just assumed that the plate bolts were what held down the choke, but it damned sure is there. That makes thinks MUCH easier than I was trying to make it.
Thanks guys!
-Xakk
Old Oct 6, 2004 | 12:45 PM
Xakk's Avatar
Xakk
Hey look at that. When I quit being stupid and actually tried the choke on, lo and behold it fits! Sheesh. I'm gonna go soak my head in a bucket now. :o
-Xakk
To Need help finding a choke
