72 Help Vin & ID
Old Oct 4, 2004 | 09:30 AM
rmartin's Avatar
rmartin
Default 73 Help Vin & ID
Need help proving or disproving correct #'s
on 1973 vette engine casting is correct
but the ID and Vin are in question
V0915CLA
13S403923
Always received good help here
Thank you
Ron
Old Oct 4, 2004 | 12:17 PM
GaryS's Avatar
GaryS
on 1972 vette engine casting is correct
V0915CLA
13S403923
Thank you
Ron
I don't have my book with me on this business trip, but I found this on the internet with a Google search:
code year ci hp tranny
CLA 1977 350 180 4 a/t
CLA 1973 350 190 4 tur hydro. 400
CLA 1974 350 195 4 tur hydro. 400
I don't claim that this is the correct information but when I get home I will look at the "Lime Book" which lists all known Chevy codes. In addition, I believe that you should have a "5" after the S in your sequence on the pad. Working from memory here.
Gary
Old Oct 4, 2004 | 12:19 PM
GaryS's Avatar
GaryS
Ooops, I should have posted that I THINK the small block codes for 72 are CKW for 200 hp engines and CKY for 255 hp LT1's. Again from memory here.
Gary
Old Oct 4, 2004 | 12:32 PM
rmartin's Avatar
rmartin
Default Sorry
It's a 73 2 top not 72
Thanks again
Old Oct 4, 2004 | 01:09 PM
PRNDL's Avatar
PRNDL
V0915CLA
13S403923
Thank you
Ron
Flint plant, Sep 15, 1972 I guess, with low #3923
CLA is base engine auto trans
does the 3S403923 match your vin?
according to black book, #3923 would have been made in October 72, so looks right from here.
So your vin should be 3923 and check your trim plate to see if info there (build date) confirms the early vin.
Old Oct 5, 2004 | 04:58 AM
hunt4cleanair's Avatar
hunt4cleanair
And you can cross reference with the emission label, code WJ which indicates a 350/190 M40 automatic with smog pump.
Old Oct 5, 2004 | 09:24 AM
rmartin's Avatar
rmartin
We have a match!
Thank you again
Ron
Old Oct 5, 2004 | 09:47 AM
GaryS's Avatar
GaryS
Ok, so I get new glasses and a remedial reading lesson.
Sorry
To 72 Help Vin & ID
