383 build up
Old Oct 5, 2004 | 10:32 PM
toyvet1's Avatar
toyvet1
Default 383 build up
I am lookung for some input on a engine build up. I am starting with a 79 L-82 engine block. Installing a Eagle Crank(10350375057i) internal balanced and uses stock 5.7 rods. Pistons to bring compressionup to about 10:1. Stock L-82 cam.1.5 rollr rockers. Intake is a Tuned Port system.The car has ramhorn manifolds and true dual exhaust system.
Does this sound like a good starting point for a stump puller engine?
Old Oct 6, 2004 | 02:19 AM
75rag4sp's Avatar
75rag4sp
Depends on how big a stump
Old Oct 6, 2004 | 02:46 AM
comp's Avatar
comp
you will need headers to get it breathing the way
it needs
Old Oct 6, 2004 | 06:47 AM
Gordonm's Avatar
Gordonm
I would ditch the cam and get one that is more designed for fuel injection. It will have more torque with the correct cam. Cam technology has come a long way sine the L82 cam was made. I agree on the headers. It will breathe much better with them.
Old Oct 6, 2004 | 07:44 AM
stingr69's Avatar
stingr69
I know a guy running a 383 with Edelbrock RPM heads and the L-82 cam. His engine builder has done a lot of them that way so he went with it. He says it is a torque monster on the road. DD2K likes it as a stump puller.
Here is a link to a small page on one of his cars (69 Camaro convert):
http://www.stratagaz.com/69LM1/1969LM1Convertible.htm
Shows other combos tried earlier so you need to scroll down a bit to see the current stroker details.
-Mark.
Old Oct 6, 2004 | 07:57 AM
comp's Avatar
comp
TPI may like a different grind better
Old Oct 6, 2004 | 07:58 AM
Ganey's Avatar
Ganey
The TPI was designed for a 305 & limits rpm a Corvette should have. Yes will work well at lower rpm. The wide LSA 114 of the L-82 cam should work fine w/ the computer. Add headers.
Old Oct 6, 2004 | 09:24 AM
Surfer69's Avatar
Surfer69
toy, I'm buying that same crank this Friday. Curious as to how much you paid for it?
Old Oct 6, 2004 | 09:27 AM
Fevre's Avatar
Fevre
In stock form the tpi intake will not be a great match for the l82 cam but with some work you can make it better. Check out this article:
http://www.thirdgen.org/newdesign/te...meseport.shtml
He used a set up aftermarket runners but it will work pretty well with the stock runners and give you 400-500 more rpm's on the top end. Should be a stump puller to 5000 rpm's.
Old Oct 6, 2004 | 10:03 PM
toyvet1's Avatar
toyvet1
258 from E-bay or about 260 from locale speed shop
To 383 build up
