Sputtering
Old Oct 6, 2004 | 02:23 PM
Fireslayer26's Avatar
Fireslayer26
Default Sputtering
What causes the engine to sputter a little bit when you turn it off?
Old Oct 6, 2004 | 02:32 PM
trotter73's Avatar
trotter73
could be the timing,
do you mean it tries to keep running after you turn the motor off?
Old Oct 6, 2004 | 04:58 PM
Fireslayer26
yes, it only does it occasionally. Sputters for a second or two and shuts off.
Old Oct 7, 2004 | 08:49 PM
Red_Shift's Avatar
Red_Shift
While I can't tell you want causes this I can tell you this problem is called "run-on" or also called "dieseling." Do a search on dieseling or try these threads.
http://forums.corvetteforum.com/show...ight=dieseling
While it's not a fix to the problem you if you have an automatic you can leave the car in drive after shuting the engine off to help with the dieseling.
Old Oct 7, 2004 | 10:21 PM
stingr69's Avatar
stingr69
Many Vettes have anti-dieseling solenoids on the carb. It allows the butterflys to close tighter when the ignition is shut off. Maybe yours is not functional. Mine was dead so I did a bubba re-wire and got it working now.
-Mark.
To Sputtering
