Tracking down original build sheet
Old Oct 6, 2004 | 10:29 PM
dragonracer's Avatar
dragonracer
Default Tracking down original build sheet
I was wondering if there was any way to find out from my vin# what my 69 came with from the factory i.e. copy of the build sheet, factory records ect. I bought my car from the widow of the original owner and she wasn't sure if he had modified the car. I looked in the usual places for the build sheet in the car and haven't had any luck.
Old Oct 6, 2004 | 10:31 PM
Xx Grave's Avatar
Xx Grave
on top of the gas tank is where the build sheet is on a vette have to pull the tank to get to it
Old Oct 6, 2004 | 10:53 PM
dragonracer
Attached to the gas tank? The car sat in their garage for the last 25 ys and it rusted out sooo.....I pulled it (oh what fun that was) and pitched it! Auntie 'Em tell me it ain't so!
Old Oct 7, 2004 | 12:06 AM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Most times they are so rotted they`re hard to decipher anyway
Old Oct 7, 2004 | 02:12 AM
jyounane's Avatar
jyounane
Default Build Sheet
Usually glued to the top of the gas tank to the left of the filler cap. If the car sat for 25 years, I would think there's still a good chance it's on there. It's a big sheet...say at least 8"x6"....it must have been missing. because I can't imagine you would have pitched the tank without noticing it.
Cheers,
Joe
Old Oct 7, 2004 | 02:34 AM
PRNDL's Avatar
PRNDL
Yes, they are commonly called "tank stickers"
....is that right? gawd what a strange word.... "tank sticker"
tank sticker?
skank stinker?
stank up the joint sitter..... sank ticker... shtank snipper...
Old Oct 7, 2004 | 03:38 AM
GaryS's Avatar
GaryS
Despite the comments, no one answered your original question. Engine information wasn't coded into Corvette VIN's until 1972. The only thing you can tell from your VIN is the build sequence: #XXXXX1 out of a total production of XXXXX2.
There have been reports of folks finding folded up sheets in the back of the instrument cluster, under the rear carpet, and stuck in the seat bottoms in the springs.
Gary
Old Oct 7, 2004 | 04:16 AM
standup's Avatar
standup
Originally Posted by GaryS
Despite the comments, no one answered your original question. Engine information wasn't coded into Corvette VIN's until 1972. The only thing you can tell from your VIN is the build sequence: #XXXXX1 out of a total production of XXXXX2.........
.....The VIN will also tell you whether it's a coupe or convertible.......that may seem obvious, but a coupe can be converted to a convertible........
....the tank sticker will tell you which options the car came with out of the factory........
.....even without the tank sticker, with a bit of sleuthing you'll be able to determine most of the original configuration.........part casting numbers, engine suffix codes, tach red line position and even the smog sticker will help with leads that would normally be on the tank sticker......
This website will get you started on a rather long, but fun journey......
http://rowleycorvette.com/stats69.html
Old Oct 7, 2004 | 05:24 AM
hunt4cleanair's Avatar
hunt4cleanair
They've also been found folded and tucked into strut brackets, stuffed into coil springs and other suspension hideaway spots. If the emission label is original, or appears such, it will also offer insights into the engine/tranny combination. In 69, it might also indicated A/C, K66 or other "heavy-duty" options.
Old Oct 7, 2004 | 06:21 AM
dragonracer
Thanks guys , at least it gives me a good start point, I appreciate the help.
Old Oct 7, 2004 | 10:13 AM
ZR-1 Mark's Avatar
ZR-1 Mark
dragonracer,
I recently bought a '77 from Florida which my Son and I are
toying with. The original owner told me that when the car
was about 10 years old, he switched the seats from side to
side so that they would wear evenly..... There was a perfect
build sheet copy under the driver's seat....
What's my point ?? The guys who assembled these cars were
apt to place the copies anywhere and everywhere in the car.
I have heard of many people finding them under the dash etc.....
Good Luck,
Mark
Old Oct 7, 2004 | 12:48 PM
1FUNVET's Avatar
1FUNVET
wow really cool info here. My car just went into the interior shop on Friday 10/1 and will be there at least a month. It's a custom interior - anyway i will call him right now and tell him to keep his eyes open for anything like that WOW - maybe who knows we might get lucky!
Old Oct 7, 2004 | 06:36 PM
dragonracer
Originally Posted by ZR-1 Mark
dragonracer,
There was a perfect
Good Luck,
Mark
Funny you should say that I found one in the drivers door..it's brittle and hard to read but a friend reccomended a document resoration firm, it will be back I hope tuesday
Old Oct 7, 2004 | 10:40 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
My car had the tank stinker and a carbon copy UNDER the carpet in the passenger firewall.
stingry's Avatar
stingry
My car had the tank sticker and a carbon copy UNDER the carpet in the passenger firewall.
To Tracking down original build sheet
