Brake Pedal Return Spring Weak
Old Oct 9, 2004 | 08:14 PM
kenko74's Avatar
kenko74
Default Brake Pedal Return Spring Weak
My brake pedal return spring must be getting weak--sometimes I have to lift the pedal back with my toe to keep the brake lights from staying on.
I see Corvette Central sells both the spring and the associated bushings.
Anyone replace one of these? Looks like I have to remove some vent interference and the steering column. Any other suggestions? Is this a PIA job?
Old Oct 9, 2004 | 08:17 PM
comp's Avatar
comp
you don't need no stinking brake pedal
