carfax please
Old Oct 9, 2004 | 09:42 PM
TAKIDD's Avatar
TAKIDD
Default carfax please
I'm serioussly interested in purchasing a 69 roadster. The vin is 1946795728788. I was wondering if anyone could run a carfax for me?
Also does the vin tell you anything else about the car? engine? trans etc.
thanks, Adam
Old Oct 10, 2004 | 05:46 AM
carl a's Avatar
carl a
they dont go back that far-----------only some time in the 80's
Old Oct 10, 2004 | 08:38 AM
Larry B.'s Avatar
Larry B.
19467 tells you that it is a corvette convertable...The next two should be 9S7 (not 5) next.... 28788 is the sequential serial number that tells you the car was built in in Sept 1969 .... 28107 was the LAST car in August. Those five numbers should be stamped on the engine id pad on the front of the passenger side just at the edge of the head. If not then you do not have the original engine. No way to tell which engine you should have from the vin.
Old Oct 10, 2004 | 09:10 AM
carl a's Avatar
carl a
larry ,,my vin is 1z37j3s432389-so i should have 32389 stamped on the block(passenger side) just below the head correct?
Old Oct 10, 2004 | 04:07 PM
carl a's Avatar
carl a
there's no numbers stamped on the pad on my engine!(just above the water pump below the head gasket on the passenger side- was told by previous owner and owner before that ,,that car was origional,,, could the #'s been milled off when the engine was stroked???
Old Oct 10, 2004 | 05:34 PM
Larry B.'s Avatar
Larry B.
The number on the engine pad shoul have two sets of numbers. One os the engine build date and the other is a derivetive of the vin ending with the last five numbers. The J in the vin tells you that you have (or should have) the base 190hp 350. When machine work is done to blocks, sometimes they mill the deck eradicating the numbers.
Old Oct 10, 2004 | 06:34 PM
carl a's Avatar
carl a
thanks larry,reason i ask is both previous owners told me matching #'s car.. then a mechanic that changed a oil pan gasket and timing chain gasket said it was a later model engine-(he said the 73 gasket was different than what fit on car now) i told him he was wrong met 1st owner -met 2nd owner (he pulled orig. motor out and stroked it) so i always wanted to find the #'s to prove mr know it all wrong
Old Oct 10, 2004 | 07:47 PM
Larry B.'s Avatar
Larry B.
Lots of good mechanics know nothing about corvettes but won't admit it. To them it's just another small block chevy. It may well be but numbers are important to some corvette buyers and owners. Auto parts stores are even worse.
To carfax please
