Front suspension measurements
Old Oct 10, 2004 | 09:59 AM
1970's Avatar
1970
Default Front suspension measurements
Can anyone tell me the factory measurement between the front lower control arm mounts on a 68-82 frame? Failing that can you give me the distance between the front and rear bolt heads, center to center, on the control arm shafts? I'm trying to figure out why I need so many shims to bring my front wheels to 0 degrees vertical. Thanks in advance.
Old Oct 10, 2004 | 10:02 AM
Twin_Turbo's Avatar
Twin_Turbo
this is in mm:
Old Oct 11, 2004 | 11:37 AM
1970's Avatar
1970
Thanks for the information. Looks like my mounts are okay.
To Front suspension measurements
