Breakerless ignition installation/general engine problem question...
Old Oct 10, 2004 | 04:24 PM
72Tornado's Avatar
72Tornado
Default Breakerless ignition installation/general engine problem question...
Okay, so I've been having problems with my 72 Stingray - car began sputtering worse and worse until it simply died on me and does not restart. Anyway, I installed a Mallory Unilite electronic conversion, but the car still did not start. The installation calls for an ignition ballast resistor, and I had to use a generic one rated at .6-1.7 Ohms, whereas the manual recommends Mallory's specific one rated at .7-1.5. After the failed attempt at starting the car, I noticed the generic resistor was smoking and the ceramic was darkened in areas...is this because it's the wrong resistor or because of a wiring error? Any other suggestions for what might be causing my problem? Original thread is here:
http://forums.corvetteforum.com/showthread.php?t=907061
Old Oct 10, 2004 | 08:15 PM
BigBlockk's Avatar
BigBlockk
When I put a Unilite on my '70 5 years ago I didn't use a ballast resister. My '70 has a calabrated resistance wire.
You may want to get a wireing diagram for your '72 and see if it has the same thing.
Hope this helps.
BigBlockk
Later.....
Old Oct 11, 2004 | 12:36 PM
jbroughton's Avatar
jbroughton
I believe that Chevy did away with the ballast resistor in '68. As BigBlockk stated, they replaced it with a resistor wire going to the coil.
Good luck!
Jeff
Old Oct 11, 2004 | 11:16 PM
72Tornado's Avatar
72Tornado
Hope this helps.
BigBlockk
Later.....
How exactly would I check if it had this?
To Breakerless ignition installation/general engine problem question...
