Solid lifter valve lash made simple?
Old Oct 10, 2004 | 06:24 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Solid lifter valve lash made simple?
Again, but I can't get the search function to work. I had a post about a year ago but can't find it. Will this work for solid lifters?
Here's what I got out of an old Chiltons.
Chilton states to start at TDC #1 and adjust:
Exhaust: 1,3,4,8
Intake: 1,2,5,7
Rotate 360 degrees and No 6 should be at TDC. Then adjust:
Exhaust: 2,5,6,7
Intake: 3,4,6,8
Old Oct 10, 2004 | 07:48 PM
Gordonm's Avatar
Gordonm
That will work but I use a method of 180 degree crank revolutions.
TDC adjust exhaust 4,8
Intake adjust 2,7
1/2 revolution 180 degrees exhaust 3,6
Intake 1,8
1/2 revolution #6 TDC exhaust 5,7
intake 3,4
1/2 revolution exhaust 1,2
intake 5,6
This is a little more precise and insures that the lifters are on the base circle. The other way will work but if you have a long duration cam there is a slight chance you could be off the base circle.
Old Oct 10, 2004 | 07:53 PM
comp's Avatar
comp
Intake adjust 2,7
Intake 1,8
intake 3,4
intake 5,6
best way
Old Oct 10, 2004 | 08:14 PM
Fevre's Avatar
Fevre
Exhaust: 1,3,4,8
Intake: 1,2,5,7
Exhaust: 2,5,6,7
Intake: 3,4,6,8
Funny Len I just put my eng back together and tried that method from Chilton's and it seemed to be a couple of the rockers where not fully seated and 1 was def up, they might have mis printed or maybe I just did the wrong one.
Old Oct 10, 2004 | 08:43 PM
norvalwilhelm's Avatar
norvalwilhelm
Exhaust: 1,3,4,8
Intake: 1,2,5,7
Exhaust: 2,5,6,7
Intake: 3,4,6,8
I can't see how this would work. I have always used the 180 degree methods already posted here.
Old Oct 10, 2004 | 09:35 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I use the 90 degree method start at no 1 at 0 deg on balancer and do intake and exhaust, crank 90 degrees do the next one on the firing order and so on, fool proof.
It's nice to have a balancer marked at 0, 90, 180 and 270 degrees for this method
Old Oct 10, 2004 | 10:07 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Thanks, that's what I was looking for.
To Solid lifter valve lash made simple?
