Brake Pads, which type to buy?
The car is not driven daily and will be used for street usage. The car typically see less than 2,000 miles a year. My main concern is stopping power. I am not that concerned about dust nor concerned about repeated stopping as in racing on a course where the brakes heat up. I just orderd in 4 cross-drilled/slotted rotors which should be here in about a week.
I chose VBP organics, which are working just fine!
Go semi-metallic, there are ways to fix the squeal, if any. Mine never squealed.
I like my rotors and organic pads are very easy on them. I use Wagner organic pads at $40 per end.
Old Organics - The best organics... More harmful stuff, less rotor wear... high heat use, the fillers glaze if overheated.
New Organics - Better for you, not as great on rotors... but still glaze.
Semi-metalic - Harder on rotors, have to get warmed up to work.
Metallic - Not for street use, you cant get them hot enough to work.
Ceramic - Hard... very high pitched squeel. They are used on some cars... but are out of place on anything they didnt come factory stock on.
Me personally, I would get a decent set of bendix pads. Made in the USA! Then I'd get some American or Canadian rotors. German steel is soft, China does a bad job getting all the crud out of the metal... and can have hot spots that warp as soon as you use them. Autozone has good pricing on brake parts.
Either way... any of the above will lock up the tires on our vettes. You have to get into some real high end tires before our brake systems have trouble. Once you get to that point... you can adress the brake fade issues, and add more clamping force. For zooming around town... and stopping once or twice your fine.
http://www.porterfield-brakes.com/
We have OEM Organic All Purpose Street Pads.
Part number is 11401 x2 : $28.71 ( all 4 calipers ).
Plus shipping.
Tony
VBP
Justin
Muskegon Brake Corvette Division
jcutler@muskegonbrake.com
800 442 0335
