Oil filter
Old Oct 12, 2004 | 01:36 AM
Steve Grodin's Avatar
Steve Grodin
Default Oil filter
I have used up my supply of AC Delco PF25 oil filters. Can some one tell me what the replacement number is?
Old Oct 12, 2004 | 01:40 AM
PRNDL's Avatar
PRNDL
PF 454 (an easy number to remember! biggest bigblock, 70 - 74 )
Old Oct 12, 2004 | 02:09 AM
Steve Grodin
Thank you.
Old Oct 12, 2004 | 04:56 AM
Buffalo Dude's Avatar
Buffalo Dude
St. Jude Donor '07
Personally I like the PF1218(?) (replacement for PF35). No pressure problems and doesn't look as squatty.
Old Oct 12, 2004 | 05:46 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Local store is always out of the 454 so I use the 1218.
Old Oct 12, 2004 | 10:35 AM
mvftw's Avatar
mvftw
I switched to 1218's since the 35's are gone...
Old Oct 12, 2004 | 10:48 AM
page62's Avatar
page62
Use PF1218 if it will fit. It holds more oil (which is good considering the oil capacity of these engines), and it has more filtering capacity
Old Oct 12, 2004 | 11:40 AM
73 Vet's Avatar
73 Vet
Do any of you use the K&N oil filter?
Old Oct 12, 2004 | 01:46 PM
pws69's Avatar
pws69
NAPA Gold - ONLY - these days!
Old Oct 12, 2004 | 03:22 PM
gkull's Avatar
gkull
Default Filter Tests!
Steve - I didn't make it to the all Vette drag is Sac. this year. Is there anyway to have the main event on Sat. instead of Sunday?
Other than that read up on this oil filter test before you make a decision on what filter to use.
http://www.scuderiaciriani.com/rx7/oil_filter_study/
Old Oct 12, 2004 | 05:29 PM
Megawatt's Avatar
Megawatt
I use K&N. One nice thing is they have a hex button on the bottom so you can take it off with a socket instead of a strap wrench.
Old Oct 12, 2004 | 05:40 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I've been using the 1218 in my Suburban and Vette, no problems. It has an anti-drainback check valve which is the only difference between it and the PF35.
To Oil filter
