Subwoofer
Old Oct 14, 2004 | 09:56 PM
Silver00V6Camaro's Avatar
Silver00V6Camaro
Default Subwoofer
what subwoofer would you go with to fit in a 75 vette. The infinity bass link or the kenwood woox or the clarion srv303. here are the links
kenwood
http://www.crutchfield.com/S-tZwPiPi...00&I=113WA62RC
infinity
http://www.crutchfield.com/S-tZwPiPi...0&I=108BASSLIN
clarion
http://www.crutchfield.com/S-tZwPiPi...00&I=020SRV303
Old Oct 14, 2004 | 10:07 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
this is my HONEST opinion, but dont waste your time putting a sub in that car.
I tried it and I couldnt fit my tops in back.
if anything, go with two 6x9's
Old Oct 14, 2004 | 10:19 PM
parklawn's Avatar
parklawn
Default sub will fit
I have built two boxes so far that fit in the back of a C-3
one with a 10" sub and 4 - 6"x9"'s ,can still close the tonneau cover.
and the other with just 2 - 6"x9"'s and the cover close with ease
The t-tops will also fit under the box as well. Would post a photo but I don't have any luck doing so.........
Old Oct 15, 2004 | 01:08 AM
RAT502's Avatar
RAT502
That clarion looks interesting, slim and compact ,wonders what it sounds like??
Old Oct 15, 2004 | 02:17 AM
munday's Avatar
munday
I tried a 12" and then a 10" can't fit my dayum tops.
Old Oct 15, 2004 | 03:49 AM
81' Corvette Guy's Avatar
81' Corvette Guy
Parklawn: Email me the pick and I will host it for you...thanks, Joe!
Old Oct 15, 2004 | 04:05 AM
cryzko's Avatar
cryzko
i fiberglassed in one 10" jl 10w6v2 in each upper back corner..... i had enough airspace and hopefully once installed i won't blow nothing apart........ i dynomatted my whole interior.........
cryzko
Old Oct 15, 2004 | 04:32 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Theres a couple of members here that have the WooX mounted on the back board, you can still get the T tops under it. and they say it sounds pretty good for the size...
Old Oct 15, 2004 | 05:14 AM
81' Corvette Guy
cryzko
Pics..bro, we need lots O pics!!!
Old Oct 15, 2004 | 09:33 AM
Crash80's Avatar
Crash80
I am one of the guys running a WooX sub in my 80 and I can still keep my T-tops stored behind the seats. I personally don't think you need a ton of sub for the tiny compartment of a Vette. Then again, I am not the license plate rattlin' type that is trying to deafen myself with 136db of sound. The WooX is perfect for giving a system a bit of "thump" without spending thousands of dollars on acres of amps and double loaded 12" boxes. There is a new version of the Basslink that looks very interesting. It is called the Basslink T. Here is a link to it.
http://www.crutchfield.com/S-qV3WsWb...earch=Basslink
Old Oct 15, 2004 | 09:54 AM
81VetteFreak's Avatar
81VetteFreak
Running two Memphis 12's in the rear of my 81 , whole lot of sound .
Dont have a problem fitting my tops in the back , they lay right on top of my box confortably .
Old Oct 15, 2004 | 10:24 AM
Scudd's Avatar
Scudd
I'd go with none of those. Go with an 8" kicker solo barrick sub. It uses
.33 cubic feet of space and hits as hard as any 10, in half the space.
It will cost a little more to have the box maid to fit in the storage bin, but at least you won't throw your money away when the amp shizts out on one of those others.
Old Oct 15, 2004 | 11:57 AM
Xakk's Avatar
Xakk
I keep thinking about a square Kicker Solo-Baric in one of the storage compartments. I've seen someone around here do it with a round one. I'd think the square one might fit better and the Solo-Baric requires virtually no air space.
At least that's my thinking, for what it's worth. It'll be next summer before I can actually experiment with this.
Old Oct 15, 2004 | 07:05 PM
Red_Shift's Avatar
Red_Shift
I'm purchasing two square Kickers probably 8's if I ever GET OUT OF THIS STINKING DESERT. Only 20 more days. Keep in mind Xakk, if you're looking for lots of sound created using the smallest space available look in to the square Kickers. Surface area and throw are what create the pressure and a square 8" Kicker has about the same surface area as a 10" round.
Old Oct 15, 2004 | 07:12 PM
GnDn's Avatar
GnDn
You need to leave your tops at home and get yourself two of these:
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Old Oct 15, 2004 | 07:18 PM
cryzko's Avatar
cryzko
Default umm
first i molded in a box in the storage compartments but after i finished that i changed my mind and relocated the subs..... one jl 10w6 will bump in the storage compartment...... it's easy to make a fiberglass box and a trim/top for the sub to mount to........
cryzko
i'll get pics tomorrow of my corner boxes
Old Oct 15, 2004 | 08:19 PM
Red_Shift's Avatar
Red_Shift
That's a really good price. That sub is still selling for $1500 at my local shop.
To Subwoofer
Old Oct 16, 2004 | 11:52 AM
Viken's Avatar
Viken
I have a single JLW6r2 going in the rear compartment behind the passenger seat, 3 amps, and 6 components, with an acceptable amount of room. Will definately post pics when the projects complete; hopefully in Dec.
Old Oct 17, 2004 | 06:28 PM
Silver00V6Camaro
nobody has really answered my question about the subs I have listed I do not want to build boxes and lose my storage compartments. So that is why I thought these subs would be good. I just wanted to see if anyone had used these subs and how they sound.
Old Oct 18, 2004 | 12:38 AM
Scudd's Avatar
Scudd
They 're all crap.....
