Squeaking while in motion
Old Oct 15, 2004 | 04:56 PM
OneBrokenSmile07's Avatar
OneBrokenSmile07
Default Squeaking while in motion
This squeaking on my 81 is really starting to get to me and I have NO idea what it oculd possibly be.
- It only happens while in motion and starts around 20mph
- Gets progressively faster as I increase speed
- It can't be a belt or anything because they run all the time and there is no noise while I'm idling.
- It sounds like its coming from the foward left side of my hood but that's as good as a guess.
- It kind of sounds like a bird chirping.
Has anyone had this happen before? I'm out of troubleshooting ideas.
Old Oct 15, 2004 | 05:15 PM
kermit1654's Avatar
kermit1654
Sounds like a Speedo cable maybe? Could just need to be lubed. That would be coming from the left side dash/firewall? That would account for the sound only happening while moving.
Old Oct 15, 2004 | 11:53 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
sounds exactly like a belt to me.... chirping is the classic description of a belt problem .
Old Oct 15, 2004 | 11:56 PM
Joe Buck's Avatar
Joe Buck
could it be comnig from the wheel? Mine used to have a similar problem, and it turned out to be comnig from my brakes...something constantly rubbing until I braked and it stopped...
Old Oct 16, 2004 | 01:17 PM
bobs77vet's Avatar
bobs77vet
this could be it.....does the chirping noise go away when you apply the brakes??? Try slowly applying the brakes when you hear the sound.... if so you have the very common problem of the brake pads floating on the rotors and squealing. on my car you can hear this occasionally at 20MPH and it goes away after that because the engine noise drowns it out.
Old Oct 16, 2004 | 01:21 PM
OneBrokenSmile07
The rotor problem is possible, because as I brake it slowly lets up. How would I adjust this to find out for sure if this is it?
(Side note: My brake light on my dash went on about two weeks ago and I thought this light was only hand brake oriented, but since my hand brake was in working condition i assumed that there was a short in the computer causing the lgith to go on. I later realized that this is for the entire braking system and when I opened my master cylinder my back chamber was almost bone dry. I refilled it, but I noticed that when I was running on low brake fluid there was no squeaking, but as soon as I refilled it came back)
Old Oct 16, 2004 | 01:22 PM
OneBrokenSmile07
(Side note: My brake light on my dash went on about two weeks ago and I thought this light was only hand brake oriented, but since my hand brake was in working condition i\I assumed that there was a short in the computer causing the light to go on. I later realized that this is for the entire braking system and when I opened my master cylinder the back chamber was almost bone dry. I refilled it, but I noticed that when I was running on low brake fluid there was no squeaking, but as soon as I refilled it came back.)
Old Oct 16, 2004 | 06:06 PM
bobs77vet's Avatar
bobs77vet
i don't think it has anything to do with the brake light... ok heres a simple test.... on a straight deserted road when the noise happens turn off the engine and listen to see if its making the noise.... if it is we know it has nothing to do with the engine.... then apply the brakes and see it it goes away.... if it does you know you have isolated the problem... be sure you don't turn the key and have the steering wheel lock... not sure on your model how your steering wheel locks. either corvette central or ecklers sells a product to eliminate this squeal i'll see if i can find and get you a part number.
Old Oct 16, 2004 | 11:49 PM
OneBrokenSmile07
That would be great. Thanksss
Old Oct 17, 2004 | 07:12 AM
bobs77vet's Avatar
bobs77vet
part number a5200 "anti squeal sleeve,stops brtake squeal,simple to install, space age plastic sleeves install with out removal of claipers and and stop squeals caused by loose fitting pads one set fits 4 calipers" $13.99 from Ecklers
Old Oct 17, 2004 | 10:24 PM
FormerPacifist's Avatar
FormerPacifist
Personally it sounds like the speedometer cable needs to be greased, i had the same problem.
Old Oct 17, 2004 | 10:33 PM
Summerfun's Avatar
Summerfun
A worn odometer could make a weird noise too!!
Old Oct 17, 2004 | 10:34 PM
81 Vette's Avatar
81 Vette
St. Jude Donor '05
First C3 General Poster!
Power Steering fluid levels??
To Squeaking while in motion
