Crooked motor?
Old Oct 15, 2004 | 04:59 PM
JoeRags's Avatar
JoeRags
Default Crooked motor?
We recently installed a new 383 in our '70 vert, and it has a 4 spd. Drove the car 2 weeks ago, did a donut or two, and parked it, no problem. Get in the car this past weekend, and as soon as I lay into the throttle, the shifter violently jolts to the right, and I hear some loud noises. Put the car in the air, and there are rings on the driveshaft where it rubbed, and its definatley not strait within the tunnel. Pull it out to inspect, and its perfectly strait. When I look at the motor from inside the car, it looks crooked in the engine bay. My motor mounts are tight, brand new, and my tranny mount is pretty new, and all looks tight there. I then fired it up again, revv'ed it up a few times, and the shifts a bit like it should, so the mounts are definatley holding (Delco rubber mounts).
Moving back to the rearend, everything looks good, is next to new, and wasnt touched during the motor swap. What could my problem be? Could I just have a bad motor mount?
Joe
Old Oct 15, 2004 | 05:05 PM
Fevre's Avatar
Fevre
What do you mean the mounts are nice and tight? With the hood up try putting the car in gear with the parking brake on and let out on the clutch some, the eng will torq up on the driver side most likely if the driver side mount is busted.
Old Oct 15, 2004 | 05:07 PM
kona's Avatar
kona
Is your crossmember in tight?
Kona
Old Oct 15, 2004 | 05:16 PM
GTR1999's Avatar
GTR1999
Joe it sure sounds like mounts. I had a sheared left mount in my car and didn't know it until I was test driving it without the shift boot one day. I noticed the tranny shifting to the right side everytime I shifted it. When I removed it, it fell in two pieces. You didn't have theproblem before the new motor right?
Gary
Old Oct 15, 2004 | 05:41 PM
Fevre's Avatar
Fevre
Gary
Forgot to mention I had one go, it does not tear apart into peices but rather the rubber separates from the metal so when it is still installed it looks fine but when you pull the eng the it will come a part.
Old Oct 15, 2004 | 08:11 PM
Z-man's Avatar
Z-man
That's the interlocking mount doing its thing...
Old Oct 15, 2004 | 08:14 PM
joe73vette's Avatar
joe73vette
Jack up on that tranny mount, I'll bet it sheared. Joe
Old Oct 15, 2004 | 09:31 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Maybe motor mounts too. Were they new with the new engine? OOPS I didn't read enough of your post, I see they were new. 383's are torque monsters, you might want something a little stronger then stock mounts, like polyurethane.
Old Oct 16, 2004 | 01:07 AM
JoeRags's Avatar
JoeRags
Yea, I guess my first thing to do is buy a set of poly motor mounts. They arent too expensive. Is there anyone who makes a poly tranny mount that will work with a '70? I didnt even think to jack up on the back of the tranny at all, the mount "looks" to be fine, but I guess it sure could be separated from the steel. That would definatley explain what happened. Thanks for all the input...
Joe
Old Oct 16, 2004 | 01:12 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
You've got a busted drivers side motor mount just like Fevre said
Old Oct 16, 2004 | 08:28 AM
GTR1999's Avatar
GTR1999
Joe stay away from the Energy Suspension tranny mount,#3.1108G, it doesn't fit corvette. I have one sitting on my bench for a year now,new in box. They fit everything but a vette even though the Summit cat says all. I used one form the other poly company in Jegs cat but I don't recall the name off hand, I had to call both poly companies direct to find out.
Gary
Old Oct 16, 2004 | 10:20 AM
Summerfun's Avatar
Summerfun
Old Oct 16, 2004 | 11:19 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Let us know what you find on this one Joe.
Old Oct 16, 2004 | 12:34 PM
JoeRags's Avatar
JoeRags
Will do Eddie70, again, thanks for all the input everyone.
Joe
Old Oct 16, 2004 | 07:58 PM
JoeRags's Avatar
JoeRags
Which motor mounts do I need? Short and Wide, or Tall and Narrow?
http://www.jegs.com/cgi-bin/ncommerc...74&prmenbr=361
I'm thinking the short and wide, will these work with the 383?
Thanks again.
Joe
Old Oct 16, 2004 | 08:03 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
I'm pretty sure its the 'short and wide' ones
if you need it, I can run out to my garage and measure one of my old mounts
To Crooked motor?
