Can Someone desktop dyno for me?
Old Oct 17, 2004 | 02:46 PM
gdh's Avatar
gdh
Olivier can you run the same ie. XR274 with either a Torker, Team G intake so he can see the difference. I am replacing my torker with the Team G this winter and will also get around to the cam swap. You will move your power curve up a bit but the difference once those secondaries on the BG open up is amazing. I have the dart heads that MountainMotor race ported so my setup is not that much different than ones that are posted other than the Torker intake and a peak hp in the 495 range.
Old Oct 17, 2004 | 02:57 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by madvette74
gransport3..
I have the 2.02 /1.60 and small tubes headers, could you try it with this configuration but with a single plane, what you believe is a good single plane...
thanks
A single plane intake adds about 15 - 20 HP...
Old Oct 17, 2004 | 02:58 PM
GrandSportC3
The dyno program only has 2 selections for intakes.. Single and dual plane... DD2000 is the program that I use and they have no intake files...
