Can Someone desktop dyno for me?
Old Oct 16, 2004 | 08:56 PM
L-82kid's Avatar
L-82kid
Default Can Someone desktop dyno for me?
Hello,
I'm planning on building a 396ci stroker motor next summer and was trying to decide on what cam to use. Can someone desktop my combo with a few different cams and let me know what makes the best power.
Here is my set up:
4.030" bore 3.875" Stroke
10.25:1 compression
World Sportsmen II heads port/polished (200cc, 2.02, 64cc)
Edelbrock perf. RPM intake
Comp 1.52 roller rockers
750cfm Speed demon carb
1 5/8" headers (will be changing to at least 1 3/4")
2.5" flowmaster exhaust
Here are a few cams I was looking at:
1. CC XR288R 288/294 @.050" 236/242 .520/.540 110LSA
2. CC 294S 294/294 @.050" 248/248 .525/.525 110LSA
3. CC XS282S 282/ 290 @.050" 244/252 .520/.540 110LSA
4. XR274R 274/280 @.050" 236/242 .564/.570 110LSA
If someone can just ran a few of those cam through I was really appericate it.
Old Oct 16, 2004 | 09:49 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
EDIT - FOUND THE SPECS!! RESULTS BELOW!!
need more details on the cam...
IVO (BTDC)
IVC (ABDC)
EVO(BBDC)
EVC (ATDC)
in order to produce accurate numbers..
That information should be on the cam card...
Old Oct 16, 2004 | 10:03 PM
GrandSportC3
found the dyno file for the XR288HR...
Here's the dyno result with the XR288:
Old Oct 16, 2004 | 10:09 PM
GrandSportC3
This one is for the 284S cam:
Old Oct 16, 2004 | 10:14 PM
GrandSportC3
here's the result for the xs282s
Old Oct 16, 2004 | 10:20 PM
GrandSportC3
here's the result for the XR274R
[/QUOTE]
Old Oct 16, 2004 | 10:22 PM
GrandSportC3
Tried the same combo with 215cc Dart Iron Eagle Heads and got over approx. 40 HP more on most combinations..
The 200cc runners are too small - especially for the bigger cams in the selection.. Your 200cc heads won't flow enough to really take advantage of some of those cams..
Old Oct 16, 2004 | 10:36 PM
madvette74's Avatar
madvette74
GRANSPORTC3
does your desktop dyno give results for the AFR heads??
Old Oct 16, 2004 | 10:44 PM
GrandSportC3
Originally Posted by madvette74
GRANSPORTC3
I have flow files for AFR heads!!
I checked and they'd add about 40 HP (AFR 195's)
Old Oct 16, 2004 | 10:49 PM
L-82kid's Avatar
L-82kid
Thanks for the info.
I want to get Iron Eagle 215cc heads with 2.05" valves but I don't think I'm going to have enough money for them.
I found this site with a guy who made 488hp with a 383 and S/R torquer heads. http://www.caspeed.com/488hp383.html
Is there any way I can make ~450hp with my current heads?
Old Oct 16, 2004 | 10:54 PM
GrandSportC3
Well - the guy with the Torquer heads is running 11:1 CR and a Victor Jr.. The Victor Jr. would automatically add 10 - 15 HP... Another reason for more HP on that engine could be that it was dynoed with large tube headers and race mufflers or open headers.. That's about 20 - 35 HP more..
I personally wouldn't go with a dual plane intake if I'd get it for free... Single Plane intakes rule!!
You could also get some porting work done on the Sportsmen heads... A good machine shop should be able to make them flow close to 215cc heads...
Old Oct 16, 2004 | 10:56 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
What are you using for exhaust I alway do mine with open exhaust this will give you some idea of what and engine ( gross HP ) dyno will give you. I bet you see closer to 450HP
That's about it for those heads without porting and some of those cams are already way too big as you will not benefit after a certain duration /lift unless you get higher flowing heads
Old Oct 16, 2004 | 10:58 PM
GrandSportC3
I used small tube headers and mufflers on DD2000..
Large tube headers and open exhaust is about 20 - 35 HP more..
Old Oct 17, 2004 | 12:41 PM
madvette74's Avatar
madvette74
gransportc3..
could you run this by??
385 stroker, 10.5.1 comp, com cam XE274h, crane roller rockers 1.5 AFR 195 heads, holley 700dp, with proform main body,Edelbrock air gap manifold, curious to what my setup would have.. I haven't had a chance to take it to the track..
thanks
Old Oct 17, 2004 | 12:51 PM
GrandSportC3
gransportc3..
thanks
What valves?? I assume 2.02/1.60's...
What exhaust?? I'll assume short tube headers with mufflers...
Old Oct 17, 2004 | 12:55 PM
GrandSportC3
gransportc3..
thanks
Here's the result with small tube headers and mufflers:
Old Oct 17, 2004 | 12:58 PM
GrandSportC3
Here's the result with open large tube headers: (approx. +35 HP)
To Can Someone desktop dyno for me?
Old Oct 17, 2004 | 01:00 PM
GrandSportC3
Here's the result with open large tube headers and a Victor Jr:
Old Oct 17, 2004 | 01:12 PM
GrandSportC3
Had problems with the pics.. you might have to re-load to get the right dyno results..
Old Oct 17, 2004 | 02:05 PM
madvette74's Avatar
madvette74
gransport3..
I have the 2.02 /1.60 and small tubes headers, could you try it with this configuration but with a single plane, what you believe is a good single plane...
thanks
