Holley Jets?
Old Oct 18, 2004 | 07:20 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Holley Jets?
You Holley guys who change jets, Do you buy the individual jets or did you buy one of the "jet" kits.
Reason I'm asking is that I'm stepping up to a 4150 and will probably need to adjust the jets somewhere along the line.
Len
Old Oct 18, 2004 | 07:48 AM
Summerfun's Avatar
Summerfun
I bought a holley jet kit for my Race Demon.
Great if you fool around with it a bit.
Pretty good deals on Ebay from time to time!
Old Oct 18, 2004 | 07:55 AM
Gordonm's Avatar
Gordonm
Get the kit. Keeps them organized and you have a wide selection to choose from. Cheaper by the bulk also.
Old Oct 18, 2004 | 08:21 AM
cw823's Avatar
cw823
Forgive me if I ask a stupid question, but #1 how do you know that you need to change jets, and #2 how do you know (when changing jets) that you finally have it right?
Old Oct 18, 2004 | 09:19 AM
norvalwilhelm's Avatar
norvalwilhelm
I bought 2 kits because I have 2 carbs but it is still cheaper in the long run.
From my experience holleys are too rich, not too lean and the richness comes from the idle circuit and not the jetting.
I really leaned out my carbs and did it all from the idle circuit and left the jets alone.
Old Oct 18, 2004 | 11:28 AM
Brettmc's Avatar
Brettmc
I just bought a few sets from the local speed shop....but prolly spent enough to buy the kit. You really need the book(s) to give you the knowledge of how the circuits work and interact if you're going to do any serious tuning. Also, while you can read plugs, an O2 sensor will be a much better tuning tool. Are you still messing around that 3310???
Brett
Old Oct 18, 2004 | 11:46 AM
stingr69's Avatar
stingr69
I started out buying individual jets at first but that got old quick. If you buy a box full you have something to keep them organized and a glance inside the box will remind you which pair are in the carb if you did not take good notes.
I bought a Holley quick-change jet kit because it looks to be easier than pulling off the hard lines each time I want to change jets on my Holley. The quick change kit includes a special fuel bowl that has 2 removable plugs in front that you can unscrew and access the jets with a screwdriver like jet tool. Not the greatest thing since sliced bread but I would probably buy it again. Makes jet swapping a 2 minute job as long as you are careful not to knock the jet off the tool.
If you realy want to learn how to tune your Holley, you need to read up the info on this web page. This is the best page on the net as far as I know concerning Holley tuning. I like it even better than the books put out by Holley. Simple and very informative.
http://www.bob2000.com/carb.htm
-Mark.
Old Oct 18, 2004 | 11:51 AM
Fevre's Avatar
Fevre
-Mark.
Have had to fish a few jets out with a wire, not fun. To bad they don't add some real metal to them so a magnet could be used.
Old Oct 18, 2004 | 11:56 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I look at it like this, I am only going up or down a few jet sizes, so I only buy what I need I have accumulated enough to cover the primary and secondary jet sizes I need for my motor, the kit comes with too many ( too small or too large ) sizes I will never use.
Old Oct 18, 2004 | 12:00 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Brett
Too funny Brett.
I'm going to switch to a 4150 today if the leaves let up.
Old Oct 18, 2004 | 12:05 PM
Brettmc's Avatar
Brettmc
You'll be glad you did.
Brett
Old Oct 18, 2004 | 12:14 PM
cicch95's Avatar
cicch95
Finalist 2020 C4 of the Year - Unmodified
By the condition (coloring) of your spark plugs after a WOT run. They will either show to rich or to lean!
-Rick
Old Oct 18, 2004 | 01:18 PM
gkull's Avatar
gkull
Years ago I went to some place like Auto-Zone and bought the the Holley jet kit box with two of each for everything from #60 - #120
I also have smaller Max-Jet bar with all the decimal nut driver jets.
You won't ever use more that 20% of them, but it makes them handy to loan out also
Old Oct 18, 2004 | 02:32 PM
The Dude's Avatar
The Dude
The problem with the kits is that you're paying for jet pairs you'll never use.
Old Oct 18, 2004 | 02:42 PM
gkull's Avatar
gkull
Oh, I should add that the nice box with all the compartments nicely lettered was also something like $35 bucks. I couldn't believe how cheap it was. It only take a few times changing jets at $3-5 dollars to add to $35 anyway.
It has room in the box for power valves, extra jets, different boosters, new needle and seats. No more running to the store 10 miles away when your working on some project or out at the races helping on some other car.
Old Oct 18, 2004 | 02:45 PM
Fevre's Avatar
Fevre
Beats running to the store and trying to find a set that 'might' be the ones. With all them to choose I find I am more willing to try diff ones untill I get the right combo. The cost of 10 individual purchases adds up to about the same cost as the kit.
Old Oct 18, 2004 | 09:37 PM
Jughead's Avatar
Jughead
St. Jude Donor '09
Thanks for that site Mark.
To Holley Jets?
Old Oct 19, 2004 | 01:49 AM
Chuck Harmon's Avatar
Chuck Harmon
I never imagined how much this was true until I got my digital exhaust analyzer. The idle circuit affected the mixture all the way up to and including highway cruising speeds. This is with just the four corner idle screws! I can change from around 13:1 a/f to over 15:1 a/f with just the idle screws at cruising speeds. Even 1/8th of a turn makes a very significant difference over a broad rpm range.
For power settings once the secondaries are beginning to open, jet changes make the difference. Get the kit.
Chuck
Old Oct 19, 2004 | 08:18 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
As far as jet size. Does a 84 jet have a larger or smaller opening than a 74? Is it that the higher numerically gives a larger opening?
Old Oct 19, 2004 | 09:20 AM
Brettmc's Avatar
Brettmc
The larger the number the more gas it will flow. Sometimes the openings are larger to get more flow, sometimes just the entry and exit are changed to change flow from one jet to the next.
Tell ya what, Len. I'll make a gift of one of my Holley books to you if you IM me your mailing address. Feliz Navidad!!
Brett
