Rear end numbers help
Old Oct 18, 2004 | 02:02 PM
L71Maynard's Avatar
L71Maynard
Default Rear end numbers help
I have a '69 BBC. I have the tank sticker so I know the car came with 4.11 gears. I pulled the following numbers off the bottom of the rear end right before the end cap. If anyone can help me figure out what I have I would appreciate the assistance.
OJ143W9E1
I looked all through the Corvette By Numbers book and can't find anything close. I verified the numbers are stamped on there with a pencil to clean out the grooves.
Thanks,
Dave
Old Oct 18, 2004 | 02:13 PM
Brutal64's Avatar
Brutal64
Dave-If I remember correctly there should be a two letter code stamped into the bottom of the pumpkin, back by the rear cover? That will tell you what ratio you should have in it. That doesn't mean that's what's in there now.
Old Oct 18, 2004 | 02:22 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
If original, a 4:11 ratio in '69 would start with the letters FB. My books only go up to 1972.
Old Oct 18, 2004 | 03:53 PM
i885744's Avatar
i885744
you got the correct numbers i think. I've got a book somewhere on the garage shelves that will tell you, I'll let ya know as soon as i find it.
Old Oct 18, 2004 | 08:16 PM
i885744's Avatar
i885744
ok, found the book. It looks like your axle was replaced at one time or another.
OJ 1978 or 1979 3.70:1 ratio positraction corvette
14 Fourteenth day
3 Third Month, March
W Warren, Michigan Plant
9E1 is a series number.
Old Oct 18, 2004 | 10:15 PM
Lotus76's Avatar
Lotus76
14 Fourteenth day
As log as you have the book out
Can you tell me if this is a 69 3:55 2CAZ111169
John
Old Oct 18, 2004 | 10:23 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
The CAZ is a 3.55 from a 1970 Vette with a Nov. 69 date.
Greg
Old Oct 18, 2004 | 11:01 PM
Lotus76's Avatar
Lotus76
Greg
Thanks Greg.
Old Oct 19, 2004 | 05:58 PM
L71Maynard's Avatar
L71Maynard
Thanks for the help!! I was looking at the other years last night and it finally hit me that it was probably that!
Dave
Old Oct 19, 2004 | 06:05 PM
73 Vet's Avatar
73 Vet
Greg
corvgreg,
Where did you find that information? Do you have all numbers for 1973?
Thank you.
Old Oct 19, 2004 | 06:26 PM
L71Maynard's Avatar
L71Maynard
For a '73:
AA = 3.55
AB = 3.70
AC = 4.11
AW = 3.08
AX = 3.36
LR = 3.36
Dave
Old Oct 19, 2004 | 07:11 PM
dragonracer's Avatar
dragonracer
Originally Posted by L71Maynard
For a '73:
AA = 3.55
AB = 3.70
AC = 4.11
AW = 3.08
AX = 3.36
LR = 3.36
Dave
How about those 69 codes....i can find all kinds of casting #'s , so if I ever find it I would like to be able to decode it Thanx
To Rear end numbers help
