When I shut my motor off I can hear coolant boiling. Not really when I drive around town, but if I run it hard, it will boil for a couple of minutes when I shut it off. Could this be a bad water pump, or is it something else? My temp gauge never goes over 200. Is it just from all the heat in the motor when you stop running the pump that does it or do I have a bigger problem?
[QUOTE=GTLocke13]When I shut my motor off I can hear coolant boiling. Not really when I drive around town, but if I run it hard, it will boil for a couple of minutes when I shut it off. Could this be a bad water pump, or is it something else? My temp gauge never goes over 200. Is it just from all the heat in the motor when you stop running the pump that does it or do I have a bigger problem?[/QUOTE
Appears you have air in the system....Do you have a closed recovery system? If not...you are sucking air instead of water back in.
Water pumps do 1 of three things. Pump water, leak out the weeping hole under the bearing because the seal is shot, or completely fall apart. They are pretty simple things realy.
I had the same thing happen to me this summer...turns out my distributor came loose, and i was running very low on timing,..caused the motor to get hot enough on a hot day to boil out of the tank after shut off.
Very likely you have either a bad radiator cap or one of too low a pressure rating.
All engines go through heat soak once fully up to temp and then shut off. The coolant temperature will always rise and if the cap doesn't hold the pressure rise from the increase in coolant temperature you will have boiling and gurgling.
From a wrenching perspective, a cap is far cheaper than anything else that you can do to reconcile the problem except for ensuring the coolant level is correct for your car. Everything else both costs more and takes more time if you're not sure what's causing it.
