[OT] Garage Heater Options
Old Oct 22, 2004 | 06:15 AM
  #41
guppie's Avatar
guppie
St. Jude Donor '08
I plan on going with a Dayton G73 heater. They run about $290
17000btu with a thermostat. Saw one in a garage twice the size of mine and it was quite comfortable.
Old Oct 22, 2004 | 06:54 AM
  #42
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Originally Posted by bertmeister
I have a Modine Hot Dawg heater in my 2 1/2 car garage. It runs on a thermostat. Does a great job and very satisfied with it.
Modine Hot Dawg
My opinion: (Heating service man, 30 years) This is what you want. Don't use ANY heater that is not vented, they are just not safe.
Old Oct 22, 2004 | 08:07 AM
  #43
desi's Avatar
desi
Wow...never thought Heaters would be such a hot topic
Thanks much for the info.
Kerosene.....smell and safety problem
Woodstove.......love to, but they are dirty, require work and will take up too much room.
Propane....clean, but may not be safe.
Electric.... small, easy and "plug and play"
I hate the cold and stay indoors during the winter just like the Vette. For my occasional use, I will try the electric one.
mjager, I will take you on your offer. I am thinking maybe we can share, I will use it in winter and it's all your for the entire summer
Old Oct 22, 2004 | 10:56 AM
  #44
backingplate's Avatar
backingplate
You can get a ceiling mounted heater that uses forced hot water. It looks just like the natural gas heaters but it has water coils with a fan .
Old Oct 22, 2004 | 11:27 AM
  #45
vetteonr's Avatar
vetteonr
I just purchased a heating element that mounts on the top of a BBQ propane tank. You can get it with one or two elements. It heats things up pretty good and it's safe. Both burners running you can get about 28 hours out of a tank. One burner running will get you about 40 hours.
Old Oct 22, 2004 | 12:07 PM
  #46
RAGGDOLL's Avatar
RAGGDOLL
Toronto Events Coordinator
mjager, I will take you on your offer. I am thinking maybe we can share, I will use it in winter and it's all your for the entire summer [/QUOTE]
Had a pretty bad day at work (see my post in OT), but e-mail me and we can plan on hooking up.
Old Oct 22, 2004 | 04:19 PM
  #47
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
I have a 60,000 BTU two speed blower between the stud direct vent gas furnace. It will take a three car garage up to 70F in about 30min. took about three hours to install once you have a gas line. cost aroudn $600. Another plus is the pilot is sealed so fumes aren't a problem. Grainger has a nice selection of these types of furnaces.
Old Oct 22, 2004 | 05:52 PM
  #48
Michel B's Avatar
Michel B
From: Ville de la Baie Quebec. A winner is just a loser who tried again.
Originally Posted by desi
If it take less than 2-3 hrs, that's fine. I usually plan ahead. Plus it's going to be turned on maybe 4-5 times a season. Stinky ones would not work, house is attached to the garage. Kerosin seems dangerous for some reason. I am looking for a convenient and economical way to heat for 4-6 hrs at a time on weekends.
Any opinions on baseboard ones?
This is my experience,, we had an unusually cold winter last year( and I do mean cold, with heavy winds almost every day, Jan, FEB,March.) My garage is similar in size as yours, and fully insulated, R-24. I've always heated it with a construction heater as you are looking at. It cost me about 300$ cad to heat one full season, that is 24hrs, 7 days. In the past I've also just used it on weekends,, it worms up the garage in about 30- to 60 minutes, with no considerable difference in my bills. I don't leave it on the floor although,, it hangs in a corner about 4ft off the ground. The one major problem I had was the air comming out of my compressor,,, it would freeze up my tools,,lololl. All in all it is very comfortable workplace.
A buddy of mine has a keroseen heater,,, man,,, I spent like 1hrs with him and had to was all my clothes to get the smell out...lololl hope this helps...
Old Oct 22, 2004 | 06:41 PM
  #49
Big Fish's Avatar
Big Fish
One more thing I could throw in here: Radiant floor heat. A small gas-fired water heater would do a great job providing you install an adequate amount of tubing in the floor before it's poured. Limit the water temperature to no more then 120 degrees or the concrete may buckle.
Old Oct 22, 2004 | 10:21 PM
  #50
desi's Avatar
desi
It helps alot. This is what I am going with. Since it's gonna be used maybe 2 or 3 weekends......plug and play, and economical.
if I were building a new garage, heated floor + forced air heater would be my first choice. I don't feel comfortable with propane, kerosene or open elements, especially with paint, paper, and chemicals around.
Thanks everyone for sharing your opinions
Old Oct 23, 2004 | 01:00 AM
  #51
MikeC's Avatar
MikeC
Desi,
In my quest for a warm garage I have ocome across the thought of using my hot water heater as the source.
I can get a 36,000btu/h , 3 speed heater for around $240CA this puts out around 2 times the amount of the heat the construction heater puts out.
The problem is the units I've found so far are meant for car heaters( ie low pressure) but this should work easily... and well- my old house had a forced air furnace that had a hot water coil in it and it worked great.
Old Oct 23, 2004 | 01:10 AM
  #52
Summerfun's Avatar
Summerfun
No views on along wall cast iron radiators??
Old Oct 23, 2004 | 01:33 AM
  #53
MikeC's Avatar
MikeC
Grossly inefficient.
Old Oct 23, 2004 | 01:56 AM
  #54
Mike Mercury's Avatar
Mike Mercury
here is my setup - propane:
the 20,000 BTU model was big enough, but I wanted to set the thermostat low... and have fast recovery. So that is why I purchased the 30,000 btu model.
I've had it for 4 years now and it works great. The exhaust vent is powered, I ran it out a side wall,
Old Oct 23, 2004 | 06:12 AM
  #55
comp's Avatar
comp
the heater that attach to a propane tank work great add are really
portable ( don't need elec)
Old Oct 23, 2004 | 08:07 AM
  #56
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
I've been going through the same heater problems.
Tried the convection...noisy as heck. Some moisture.
Tried propane bullet...plenty of heat, but moisture on EVERYTHING. This is BAD NEWS guys. While the Vette body is fiberglass, the metal parts inside and outside the car will get wet. That includes exposed wiring. If you only use the heater when you are in the garage, the hot-cold-hot-cold WILL cause a lot of condensation.
Electric...not enough output.
A lot of the heat descision depends on...
1. If your garage is WELL insulated. Garage door, walls, and at least block off the ceiling. Cover the walls with plywood, if possible, after insulating.
2. If you are gonna heat it day and night or just when you are working in there.
3. Cost of fuel
Another factor you have to think about is open flame. If you are working with any part of the fuel system, or your car has a leak in the fuel system, gasoline vapors can build up to the point where WHAMMO...an open flame like a convection, propane or kerosene heater sets it off.
I plan on insulating my walls, garage door, and laying foam sheets along
the roof braces to insulate the garage. A couple of electric heaters with thermostats should do the trick, and I'll leave them on all winter.
Dep
Old Oct 23, 2004 | 09:01 AM
  #57
Summerfun's Avatar
Summerfun
That's why I'm thinking of either in floor water radiation or 4 or 5
cast iron radiators along the wall.
I plan on leaving them on all winter as well to keep heat at above 35 degrees at the least.
I don't know why you would think that cast iron radiators are inefficient
My house is heated by baseboard aluminum finned hot water radiators, and while they are not the big AZZ cast iron radiators it is THE BEST heat from an efficiency point of view......that's why all the new houses are equipped with them here on the north east coast
Water circulates through your whole system and is heated by an oil(diesel) furnace. I have a six zone setup in my house and my fuel costs are less than anything else used around here. That is with continuous heat above 75 degrees.
The only drawback of those big radiators is that if you use them on and off, it takes a while to heat a place and they take up space.
Hot water radiation heat is cheaper than electric heat as well, around here anyway....I don't know how much electricity prices fluctuate from place to place...
Am I missing something?
To [OT] Garage Heater Options
Old Oct 23, 2004 | 12:42 PM
  #58
DJ Dep's Avatar
DJ Dep
"Am I missing something?"
Yes...wait till you see the price of heating oil this winter
Old Oct 23, 2004 | 12:44 PM
  #59
Mike Mercury
I think a desicion will need be made as to whether you intend to keep the shop ALWAYS heated at near-normal temps, or you want to keep it at ... say 45 degrees when not in use.
If the latter, then you will need a "fast recovery" heating system.
Electric baseboard, hot water, and radiant types are typically slow recovery systems. I once tried electric baseboard heat, and it took about 4 hours to get things warm enough. Radiant type electric heaters got "me" warm somewhat quickly... but the floor, tools, and shop surfaces remained frigid for hours after turning up the radiant heat.
Forced air systems (with a decent blower) get the temp up fast - including the floors, tools, and shop surfaces. I only use my shop about once a month... maybe for a weekend. It wasn't practical to keep it at 60 degrees the entire month; just to bump it up to 65-68 for just 2 days out of the month. I needed fast recovery and the pictured ceiling mounted propane heater did the trick. I can move the thermostat from 45 degrees to 65, and within 20 minutes have a warm shop to work in.
Old Oct 23, 2004 | 01:11 PM
  #60
Summerfun's Avatar
Summerfun
Yes, I forgot about that...
