power antenna ??
Old Oct 22, 2004 | 07:09 AM
sewanhaka62's Avatar
sewanhaka62
Default power antenna ??
hi on my wife's 73.....the power antenna goes up alright but some times it doesn't go back down,it will if you give it a little push....is it on is way out or is it some thing simple like a bad ground...thanks bob
Old Oct 22, 2004 | 07:40 AM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
may be dirt...or simply the age...... you could connect 12V directly to the antenna and see if it works - if it doesn't work then you know it's the antenna and not the wiring. The wires are all accessible from under the car.
Old Oct 22, 2004 | 06:46 PM
72GACRZR's Avatar
72GACRZR
And clean all the contacts you can reach.
Old Oct 22, 2004 | 07:03 PM
gh78's Avatar
gh78
If it quits or breaks DO NOT replace with an after market even marked ac-delco!!! Their made in china and are crap. I bought on and it lasted 2 months!!Go with a fixed antenna if you need a new one
To power antenna ??
