No Brake Lights - Again!
Old Oct 22, 2004 | 06:16 PM
Jim Shea's Avatar
Jim Shea
Default No Brake Lights - Again!
Last year my brake lights didn't work. Every once in a while, they would work ONCE then nothing! After much searching I found a capacitor wired across the brake light switch. Bubba had wired it sometime before I bought my 1975 Vert 18 years ago. I figured that the capacitor went bad with time. I removed it and my brake lights seemed to work correctly.
Now I seem to have the same problem again. (But there is NO capacitor in the circuit.)
I have turn signals, hazard flashers, and running lights. Just very intermittant brake lights.
I checked the orange wires to the brake light switch - 12 volts. I checked continuity of the switch itself - seems to function correctly. So now I am led to the Saginaw steering column. BTW, a NOS T&T turn signal switch is a VERY difficult part to find.
Any ideas would be appreciated?
Old Oct 22, 2004 | 06:34 PM
72GACRZR's Avatar
72GACRZR
Jim, before going into the column, you might try disconecting the column fed and using a jumper to apply 12 volts to the hot side of the brake switch and then operate it by hand to see if you get the same results(bad switch or beyond not coulmn). Then try applying power to out lead (if lights work, bad switch, if not bad wire to rear). Since turn signals and hazards work fine and use the same blub filaments and grounds, that just leaves switch, and power wireing to be at fault. ( I think,could be way off base, but would try above).
Old Oct 22, 2004 | 06:52 PM
81' Corvette Guy's Avatar
81' Corvette Guy
Old Oct 22, 2004 | 07:05 PM
Corvettes White's Avatar
Corvettes White
Originally Posted by Jim Shea
... Bubba had wired it sometime before I bought my 1975 Vert 18 years ago. ...
Jim, that Buba worked for GM. The capacitor in the line suppresses popping that you might otherwise hear on the radio. Off the bat, I recall the one you found, one on the blower fan and one on the coil. These were all factory installed when you ordered the radio. And, yes it is just taped on there.
George
Old Oct 22, 2004 | 08:26 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
just for kicks, why not run a jumper cable from the switched side of the brake switch to the bulb socket??? if this is where the problem is ( which you suspect) the brake lights should work. then your nightmares are confirmed and good luck....
Old Oct 23, 2004 | 10:54 AM
Jim Shea's Avatar
Jim Shea
Looking at the electrical schematic, I should be able to disconnect the body harness from the steering column turn signal switch. Then I should be able to jumper the White wire coming from the brake light switch directly to the Dark Green and the Yellow wires going to the rear lights. If they go on when I depress the brake pedal, the problem should be in the column itself.
BTW, what I called a capacitor that was mounted on the intake manifold was actually the tachometer filter.
The capacitor that was connected across the brake light switch (that I removed last year) was spiced into the wiring with those blue clamshell splicers that you can buy at Radio Shack etc. I have never seen wiring from the factory with those blue splicers. Maybe the dealership may have installed the capacitor, but I doubt that St. Louis did.
I can't trouble shoot any more today - big game between Purdue and mighty Michigan that I need to watch.
Old Oct 23, 2004 | 11:16 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
One thing you might try, disconnect the brake light switch and put a jumper across at this point. If this makes the brake lights come on, you know the switch is intermittent and needs to be replaced. Make sense?
Old Oct 23, 2004 | 12:16 PM
75rag4sp's Avatar
75rag4sp
How big a deal is it to replace that switch?
I thought the switch was a $3 part. replace it and see what happens...worst case you have a fresh switch.
Old Oct 23, 2004 | 12:47 PM
Paul L's Avatar
Paul L
Jim,
I recently broke one of the little legs on one side of my turn signal switch cancelling cam. You may recall the post over in C2. I very quickly learned how rare that part is. It is unique to 1967 and 1968, coinciding with/sandwiched between the introduction of four-way flashers in 1967 and moving the ignition to the steering column in 1969. Most catalogues don't even show a listing and if they do the word "discontinued" is alongside.
With the help of the NCRS people I was able to locate one at the company shown below. I recognize that this is not going NOS but I can assure you the quality is top-notch and fitment was perfect. Just a tip in case you need that switch.
http://shee-mar.com/
Old Oct 23, 2004 | 01:28 PM
Jim Shea's Avatar
Jim Shea
Thanks,
I eMailed Shee-Mar for a quote on the T&T turn signal switch.
Jim
Old Nov 9, 2004 | 06:24 PM
Jim Shea's Avatar
Jim Shea
My problem continued. Every once in a while the brake lights would go on when I depressed the brake pedal. They might even work a few times and then they stopped going on. Turn and hazards continued to work all of the time when actuated.
I connected a new turn signal switch to the column and the problem remained.
I removed brake light switch and checked for continuity with my multimeter. It showed continuity every time I released the plunger. I depressed the plunger slowly; I depressed it partially and back; I depressed it quickly; I released it slowly; I could not trick it into not working.
75rag4sp suggested to just replace the brake light switch anyway. I purchased a new switch and hooked it onto the underdash harness. The new brake light switch fixed the problem.
Any thoughts as to why the original white switch can be intermittant when hooked in the vehicle circuit, yet check good 100% of the time when checked for continuity?
Old Nov 9, 2004 | 08:06 PM
mrvette's Avatar
mrvette
Jim, if it makes you feel any better, I fought my brake light switch to the exact same conclusion about 2 months ago....
I took the old one apart, the contacts are a mess....
I tried to fix it...same thing.....
think I used an instock NAPA switch for 8 bux.....
sorry I didn't spot post earlier....
GENE
Old Nov 9, 2004 | 08:17 PM
NHvette's Avatar
NHvette
Surprised Gene didn't answer the last question.
With corroded contacts, a meter will show continuity - since
it uses very little current to check.
However, the brake bulbs are a very low resistance, so lots of current
will flow when connected to them. If the corrosion contributes just a
few Ohms (or tens), it can be enough to limit the current and
effectively shut off the bulbs. If you pulled the lenses, you might have seen a dim glow.
Old Nov 9, 2004 | 11:28 PM
Jim Shea's Avatar
Jim Shea
I learned something new today.
Thanks,
Jim
Old Nov 10, 2004 | 09:51 AM
lars's Avatar
lars
Hi Jim!
Just saw your post and thought I'd check in and say hello!
I had exactly the same issue on my '85 recently. I finally figured it out with the following high-tech troubleshooting process:
Removed the kick panel under the steering column. Whenever the brake lights failed, I give the column/switch area a swift kick. Brake lights would work again. Conclusion: bad switch. Replaced the switch, and all is well. I bench-tested the old switch and could not get it to fail under any conditions, so I re-inrtalled it just to see: no brake lights. New switch is now working great, and I don't have to kick my car before applying the brakes anymore.
Old Nov 10, 2004 | 09:54 AM
norvalwilhelm's Avatar
norvalwilhelm
this is the first thing I would do. Twice I found a faulty switch. These are $3.00 switches, nothing special and the local parts store has bins full of them.
Old Nov 10, 2004 | 01:35 PM
theandies's Avatar
theandies
Cool, I though Bubba put the capacitor on mine too a few months back. I removed it and it seemed to help a bit but I still have the same problem you had. My switch doesn’t make a popping noise in my radio but I hardly use the radio . I also bench checked my switch several time without failure. I can "double press" my pedal when the lights fail to work and the second press will get them to work. I can tell when I am driving because of the fiber optics light monitoring system. I am going to get a new switch now.
Gene - Do you have a NAPA part number???
Old Nov 10, 2004 | 03:58 PM
ZD75blue's Avatar
ZD75blue
Thankfully on these old cars they dont give you to many electrical possibilities! Its either the switch, the bulb, the wire... or no power/no ground!
A friend of mine works on BMW's... they have headlight modules, electrical computers that control the HID lights! 250 bucks for the panel, 250 bucks for the light that wouldnt come on... the cause non-repairable panel with a burned out diode!
The more I learn about electronics, the more I like the service bulletin that Ferrari sent out (Joke...) back when Jaguar was beating their sales in the 70's... "Replace wiring when smoke has been let out of wire."
A jab at lucas... and their wiring systems! Some of those things are nuts! Who would think up a hot wired body... where all the wires going to the parts, are the ground!
To No Brake Lights - Again!
