Heat Riser Elimination
Old Oct 24, 2004 | 07:05 AM
Blackened 79's Avatar
Blackened 79
Default Heat Riser Elimination
The heat riser valve on my 79 L-48 rattles and i'd really like to get rid of it. I've seen a spacer that can be substituted for the valve...anybody know where to get one ?
Old Oct 24, 2004 | 07:56 AM
Paul L's Avatar
Paul L
You may not wish to fight with those exhaust manifold studs. That can turn into a nightmare. A local muffler shop welded mine open and rattle-free for about $5.00.
Old Oct 24, 2004 | 07:59 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
time for headers!!!!!!!!!!!!!!!
Old Oct 24, 2004 | 08:40 AM
Gordonm's Avatar
Gordonm
Zip and Corvette Central have the spacers in both 2 inch and 2 1/2 inch. You should have a 2 inch spacer.
Old Oct 24, 2004 | 09:39 AM
foundvettelifeisgood's Avatar
Old Oct 24, 2004 | 10:40 AM
Mike Mercury's Avatar
Mike Mercury
ding... ding... ding; we have a winner !!!
Old Oct 24, 2004 | 01:46 PM
Shark Racer's Avatar
Shark Racer
More like...
tick... tick... tick... we have a winner!!!
I went the headers route and don't think I'll ever look back. Before that though, I used a coat hanger to keep embarrassment away.
-Steve
Old Oct 24, 2004 | 01:55 PM
markdtn's Avatar
markdtn
Make your own spacer from the old one. Take it off, cut the flap out, pull the shaft; then you can weld, thread and tap for a bolt, or use a plug to block the hole. Virtually free. You do have to deal with the studs for this one, so consider that.
Old Oct 24, 2004 | 04:11 PM
bertmeister's Avatar
bertmeister
I did the same thing. I believe a 1/4" pipe tap and plug fit the shaft hole.
To Heat Riser Elimination
