Parking Brake Install
Old Oct 25, 2004 | 09:33 PM
Edzred72's Avatar
Edzred72
Default Parking Brake Install
I need to install a complete parking brake system on the 72 and can't find any pics, diagrams etc on the subject. The cables are here, but I don't have any actuating hardware/shoes on my car. I've bought all stainless and need to see how to install.
Thanks Guys
Eddie
Old Oct 25, 2004 | 11:43 PM
68/70Vette's Avatar
68/70Vette
I think you can find a discussion at corvettefaq.com about how to install them. Also there's been some previous threads on this forum discussing "how to...."
I bought a set of the stainless steel parts from Mid-America and they sent along an illustration showing how the parts fit. I bought a set lately from Stainless Steel Brake Corp. and there was no instruction,illustration, etc. (However, whenever I've had questions about installing their stuff, they've been very responsive both by telephone and E-Mail.)
Since the emergency brakes parts fit between the stub axle flange and the cast iron bracket for the disk brake caliper, it's difficult to work in that small space. I think one key bit of knowledge is that one of the little springs has to be installed compressed. People who describe this operation compress the spring with dental floss, and when in place they use an X-acto knife to remove the floss. You're going to need some long needle nose wire pliers.
Old Oct 26, 2004 | 12:10 AM
62fuelie's Avatar
62fuelie
There was recently a link posted on either this forum or the C1/C2 forum with instructions and pictures for replacing the brake hardware without removing the spindles. It's a real PITA, but probably less PITA than removing the spindles.
Check posts for the last week or so on both forums. You'll probably be able to find it.
Old Oct 26, 2004 | 12:13 AM
68BLUEVETTE's Avatar
68BLUEVETTE
I used tie wraps to compress those springs. I was fighting for about an hour until I did that. I may be able to snap some pictures if you want. Mine is partially dissasembled, so I can put it back together piece by piece and take pictures along the way for ya. Not sure if I am going to have the time to do it this weekend or not though.
Old Oct 26, 2004 | 08:34 AM
Edzred72's Avatar
Edzred72
Thanks for tthe replies guys. It's hard to figure out how to install everything when there's nothing there!!
Eddie
Old Oct 26, 2004 | 09:14 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
On both sides you have the pins that come through. One side you can hold it with your finger and the other side can be a nightmare. You caliper mounting bracket will have a divit on 1 side where the pin goes. Fill that divit by folding up a little piece of paper or something and tape it down. Than set your pin on it and put the backing plate over top. This will save you lots of time.
I hope you didn't get the SS parking brake shoes. They are arched wrong and you will have to sand down most of the pad to allow the rotor to be installed. Using new GM style shoes are your best bet. Hope this helps.
Old Oct 26, 2004 | 02:17 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
great diagram!
Old Oct 26, 2004 | 02:23 PM
Twin_Turbo's Avatar
Twin_Turbo
The easiest way to get those springs & lock cups over the anchors is to either tie the spring down w/ a wire and after install burn the wire or get a spring tool for it
Old Oct 27, 2004 | 08:08 AM
Edzred72's Avatar
Edzred72
This diagram is priceless!! Just what I needed. Thanks so much. BTW...I did buy GM shoes. Heard the stainless were trouble.
Eddie
Old Oct 27, 2004 | 08:28 AM
Van Steel's Avatar
Van Steel
Old Oct 27, 2004 | 08:32 AM
theoUK's Avatar
theoUK
Lucky I just read this thread - I was getting ready to order the S/S shoes. Change of plan, then!
OK, so the SS shoes are dubious, but what about the SS spring and hardware kit? Any views?
To be honest, putting in SS shoes might be overkill anyway- I guess just the stainless springs and hardware kit would suffice, being as that's where most of the rusty pivots/interfaces would occur in the stock setup.
Mind you, there's "stainless" and then there's "stainless"- - who knows what type I got in the SS hardware kit I've just bought. The quality looks ok, and the similarity to the stock pieces is fine. I guess it's just a matter of time, to see how "stainless" those bits really are!
Old Oct 27, 2004 | 11:31 AM
Van Steel's Avatar
Van Steel
I actually used to manufacture all the SS parking brake hardware. You wil have no problems with it. Everything is within spec to original. I just wouldn't do the shoes. There is a new guy making them also out of TX but I'm not sure on his quality. Haven't seen them yet. Just heard some things.
Old Oct 27, 2004 | 01:26 PM
theoUK's Avatar
theoUK
Cool, I respect your advice!
Glad I happened on this thread now. Saved a few dollars aswell.
Cheers!
Old Feb 15, 2013 | 09:24 AM
Don Lind's Avatar
Don Lind
6th Gear
Thanks for posting the video on YouTube... Putting the top spring on last made all the difference in the world for me. So much easier. Thanks again!
Don
Old Feb 15, 2013 | 11:22 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Chris@VetteFinders
great diagram!
Yes it is. Makes it look like a piece of cake with no hub in place. With the hub in place, you play peekaboo with everything.
To Parking Brake Install
