Engine Experts: Figuring Compression Ratio
Old Oct 28, 2004 | 11:23 AM
page62's Avatar
page62
Default Engine Experts: Figuring Compression Ratio
Okay...yet another head question:
If my stock smog heads are currently 76cc, and my CR is 8.9:1 (we could say 9:1 for the sake of argument), what CR could I expect using heads with these chamber volumes:
72 cc
68 cc
64 cc
Also, what's the max CR I can get away with (using 93 octane pump gas) with aluminum heads and iron heads (non-vortec).
Old Oct 28, 2004 | 11:27 AM
Glensgages's Avatar
Glensgages
http://www.smokemup.com/auto_math/compression_ratio.php
I'm running 10.3:1, iron Dart II heads, 292H cam, on straight SUNOCO94, but have run AMOCO93 on occasion.....
Old Oct 28, 2004 | 02:46 PM
mandm1200's Avatar
mandm1200
This shoud be in the ballbark:
72cc +0.35
68cc +0.8
64cc +1.2
The second part is a little tougher, it will depend on the cam and the heads. For Aluminum heads I say 10.0 to 12.0. Standard Iron heads 9.0 to 11.0. For a shorter duration cam say under 260 degrees stay on the lower end of the scale. Over 300 degrees then the upper end. Cams in between will naturally fall in the middle. I would check the cam manufacture and see what they recommend.
To Engine Experts: Figuring Compression Ratio
