How low will it go
Old Oct 28, 2004 | 07:21 PM
motown 71's Avatar
motown 71
Default How low will it go
Howdy all, good to be back home, been in Kuwait for a while.
Anyway, I have new springs from VBP and they sit ok but I would sure like to cut one coil out but not sure how much this will lower the
front end, Any one know ??
Thanks !
Old Oct 28, 2004 | 07:28 PM
flynhi's Avatar
flynhi
Welcome back! Thanks for your service....
I think one coil is worth about 3/4 to 1".
Old Oct 28, 2004 | 07:48 PM
motown 71's Avatar
motown 71
Thanks, one more question.......should I cut it off the top or bottom?
Old Oct 28, 2004 | 07:59 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Bottom, where the spacing is larger.
I cut off 3/4" off stock SB coils and droped my front end 1 ". Each Vette is different, there's no universal formula. Start with a 1/2 coil and see where that gets you.
Welcome back.
Old Oct 28, 2004 | 09:35 PM
motown 71's Avatar
motown 71
Thanks again !!
Old Oct 28, 2004 | 11:17 PM
roger's 2937's Avatar
roger's 2937
You must cut the top of the coil and make sure when you reassemble the spring that the top coil end goes in the "pocket". It takes a little jiggling around but you can get it there. I recently did this on my '68, cut approx. 1 1/3 coil on each side and it lowered the car 1.75 which was exactly my plan-the top of the fender well covers about half of the tire tread(225-70-15). Good luck-Roger B.
To How low will it go
