Need help with a Piston Stop question
Old Oct 29, 2004 | 07:42 PM
Mr D.'s Avatar
Mr D.
Default Need help with a Piston Stop question
I picked up a piston stop from summit and it is the short thread type and my plugs are the long thresd type. Anyway, I installed it and screwed the bolt all the way in and and the piston does not hit the stop???? Whats going on here???? I would think it would hit. I turned the engine over by hand several times.
Old Oct 29, 2004 | 07:47 PM
comp's Avatar
comp
what the part # ???
Old Oct 29, 2004 | 07:54 PM
Mr D.'s Avatar
Mr D.
Proform P/N 66792, I'm using it on a 427 with Edlebrock performer heads
comp's Avatar
comp
is it the Proform screw in head ?????
Old Oct 29, 2004 | 07:55 PM
Mr D.'s Avatar
Mr D.
yes, it has a screw in head
Old Oct 29, 2004 | 07:56 PM
comp's Avatar
comp
it looks like it is ajustable in the book here
Old Oct 29, 2004 | 07:59 PM
Mr D.'s Avatar
Mr D.
it is, I install the pulg end in the head and screwed the bolt all the way in. There is not much to the process.
Old Oct 29, 2004 | 08:04 PM
comp's Avatar
comp
need to grt a longer bolt then
Old Oct 29, 2004 | 09:02 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
You got further than I. I couldn'y get the thing to screw into the head. I think the threads were different. I used a plastic straw to feel for the top of the piston.
Old Oct 30, 2004 | 12:15 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Easy does it.
Ya know it takes a very light touch to prevent bending that piston stop. I recall bending it and having to turn it towards the piston. Had to take measurements several times get the feel of it without bending that stop-bolt and get a repeatable measurment. Even with all the sparkplugs removed the crank tries to surge and smack the piston when turning just by hand/wrench. And i read warnings that u can hole a piston if not careful.
But i can c that on a BB the chamber could be large enough such that stop-bolt may not reach the piston. My 69cc chamber sb with stock dished pistons seemed to use most of that stop-bolt length.
I have heard of a tricky homemade gage rather than a piston stop. Take an old (or new) sparkplug and gut it of porcelin and electrode. Find rod or tubing to fit & slid into chamber. Mark rod with a tape stop and watch for movement. Record clockwise degrees then cc degrees and divid the difference by 2.
Hope this helps. cardo0
Old Oct 30, 2004 | 03:04 PM
griffths's Avatar
griffths
Originally Posted by cardo0
...I have heard of a tricky homemade gage rather than a piston stop. Take an old (or new) sparkplug and gut it of porcelin and electrode. ... cardo0
I have done the above out of necessity and would not recommend it unless you are in a bind. It took FOREVER to smash all of the porcelain out of the old sparkplug then thread the hole for a bolt but I digress. When I used it I had to thread almost the entire bolt into the cylinder on my BB before I could get the piston to touch it but once I got the bolt to hit the top of the piston there was a very definite stop. You would have to be really torquing on the end of the crank to bend the bolt in my setup. The whole project took almost a day between making the tool and figuring out TDC so I could set my timing per Lars paper and when it was all said and done the factory mark was dead on but at least I know that now.
Old Oct 30, 2004 | 03:46 PM
cardo0's Avatar
cardo0
Default Now i want 1.
Hey, nice tool griffths! Something else to add now to my tool list.
To Need help with a Piston Stop question
