Bad freeze plug on 69 corvette
Old Oct 31, 2004 | 09:08 PM
Bills17n72's Avatar
Bills17n72
Default Bad freeze plug on 69 corvette
Hello
I have a 69 ,and the freeze plug on the drivers side behind the motormount is leaking.This is a 350 block ,can someone tell me the steps I need to do to change this plug.I changed the one on the same side towards the rear of the moter ,but now the one is leaking towards the front of the motor.
thanks for the help Bill
Old Nov 1, 2004 | 09:33 AM
Surfer69's Avatar
Surfer69
How did you pull the one behind it out?
Old Nov 1, 2004 | 09:44 AM
Larry B.'s Avatar
Larry B.
Since you have had two leak, the rest most likely leak soon. There are two between the engine and trans. If it were me.... I'd pull the engine and replace them all .. That's the only way to go if you want to drive without worrying about it or getting stuck somewhere on the road.
Old Nov 1, 2004 | 07:01 PM
Bills17n72's Avatar
Bills17n72
Thanks guys
I think I will pull the engine ,and do it right!!!!!!!!!!
have a good week Bill
Old Nov 1, 2004 | 07:52 PM
litevette's Avatar
litevette
Default jb
JB Weld worked great on mine. I've used it on other cars in the past too. If used corectly (clean area, allow to cure) it will work just fine.
To Bad freeze plug on 69 corvette
