Matching #'sssssssssss
Old Nov 1, 2004 | 10:19 AM
stewyj's Avatar
stewyj
Default Matching #'sssssssssss
Where do you check on a 77 to find the #'SSSSSSSSSSSSSSS to see if they match ?
Old Nov 1, 2004 | 10:27 AM
Larry B.'s Avatar
Larry B.
The vin number is on the drivers side windshield pillar. The last five digits of the vin number should also be stamped on the flat surface of the engine block just in front of the passenger's side head. The transmission also has a similar number but depending on which trans you have ocations are different.
