Help/?? with BBC pushrods
Old Nov 1, 2004 | 02:45 PM
Hvymtlc5's Avatar
Hvymtlc5
Default Help/?? with BBC pushrods
Looking at roller rockers set up for a new 454 engine I'm building. What is the stock pushrod setup 3/8 or 7/16? All the aftermarket rollers show/require 7/16 guideplates. Just a heavier duty setup?? I noticed on my engine some of the pushrods are two piece.... If someone could explain..........
Old Nov 1, 2004 | 03:33 PM
Steve's74's Avatar
Steve's74
Various 454s came with either 3/8 or 7/16 pushrods. I believe the "standard" performance engines came with the smaller diameter, with the stronger engines having 7/16 diameter pushrods. Having said that, I believe the parts catalog may have even listed three different sizes when I was trying to replace the bent and broken ones on my '74 LS-4.
I suspect the aftermarket sizes pushrods in 7/16 only, since they would be looking at the strength issue (high rpm). I can't explain the two-piece units that you are referring to on your engine without a picture, however, in many cases, an engine builder may want to change the length of the pushrod to make for correct rocker arm geometry. Your engine may be the recipient of pushrods designed to make changing the length easier.
Steve
Old Nov 1, 2004 | 03:52 PM
Hvymtlc5's Avatar
Hvymtlc5
THis is the first chevy I've toyed with in a long time and something makes me want to add the rollers (not sure if they are really needed or not) while the engine is apart. I'll check to see what pushrods I have when I go home. I'm assuming the 7/16 pushrods can be used on a 3/8 engine if the guide plates are changes? Don't have to do anything with the lifters do I?
Mike
Old Nov 1, 2004 | 04:22 PM
Ironcross's Avatar
Ironcross
Standard pushrods for a hydraulic cammed big block chevy is 5/16. Performance solid lifter engines from GM used a 3/8 pudhrod in the early models. Some subsequent high horsepower solid lifter engines were also 7/16 equiped. In any event, to use the larger diameter push rods even on the hydraulic cam engines will require matching guide plates. Some of the larger performance push rods were a different material part way up where it would go through the guide plates. Aftermarket roller rocker arms are not necessary in any of the engines and are really not that reliable and will probably not fit under a stock valve cover anyway.
Old Nov 1, 2004 | 08:30 PM
nxfirebird's Avatar
nxfirebird
Mike
you don't need 7/16 push rods at all, in a mild motor, in fact i have Comp 3/8s push rods in my 476, it has a .730 lift cam with almost 800 lbs of spring pressure open.
Old Nov 2, 2004 | 11:30 AM
Hvymtlc5's Avatar
Hvymtlc5
So no real HP increase with the rollers? That's what I was after. I heard 10hp increase or so...not too bad for a couple hundred dollars.
Old Nov 3, 2004 | 01:21 AM
Solid LT1's Avatar
Solid LT1
7/16" was L-88 hardware. Today in "modern times" we use 3/8" push-rods in BB Chevy's because the 7/16" stuff weighed a TON and although they are stronger, they can cause valve float due to their excessive weight. Roller rockers won't necissarily add a lot of HP but, will reduce oil tempratures and give you consistant rocker arm ratios. I like the Comp Cams Pro Magnum steel roller rockers over aluminum rockers (unless you go the "shaft" rocker route.)
Old Nov 3, 2004 | 11:08 AM
Ironcross's Avatar
Ironcross
Well not exactly, most of the performance push rods "3/8-7/16" are light weight chrome moly. Only the high HP BB chevys used them. Most factory 427 L88`s were 3/8. The later 454 LS7 that was never installed in any GM product did use 7/16 as standard equipment. High lift camshafts and the related valve springs that go with those high RPM "7000+" packages placed severe loads on the push rods requiring the larger diameter. However there is no difference in the performance of the 3/8-7/16 rods, only stronger.
Old Nov 3, 2004 | 03:44 PM
Steve's74's Avatar
Steve's74
Yup, that brings back the memory. There were three different listings in the parts catalog; my LS-4 uses 5/16 pushrods as OEM.
Steve
To Help/?? with BBC pushrods
