less expensive trailing arm tools ??
I Am A Tool Freak And Love Snap On Tools But I Just Cant See
Paying 500.00 For A Few Tools That Are Used A Couple Of Times
And The Same Tools Would Only Cost You About 100.00 At Harbor Freight If They Had Them.
and the measurement tools (dial guage and magnetic base from HF)
I used an old spindle with the outer shoulder ground down
to setup the bearings. I made a bearing splitter, but I would
suggest buying one (HF has 'em cheap). You will also need a
bearing packing tool (cheap also). A couple lengths of 1/4"
angle iron, some chunks of 4x4, and the old bearing races
for pressing out/in the bearings.
I borrowed the press, so it ended up costing me less than $50
for all the tools I needed to buy. Find an old spindle to use for
setup. Runout doesn't matter - but you need good threads on the end.
-Chris
spindle knocker - to remove the spindle from the carrier - $12:
http://cgi.ebay.com/ebaymotors/ws/eB...sPageName=WDVW
BFH (Big F'n Hammer) - to hit the knocker with - $9:
http://www.harborfreight.com/cpi/cta...emnumber=46823
Bearing Separator- to remove the outer bearing from the spindle - $13:
http://www.harborfreight.com/cpi/cta...temnumber=7343
tools used to set up the new bearings:
Spindle setup tool - worth it's weight in gold - $40:
Dial indicator - to check end play - $10:
http://www.harborfreight.com/cpi/cta...emnumber=33675
Magnetic Base - to support Dial Indicator (the fine adjustment model comes in handy) - $18:
http://www.harborfreight.com/cpi/cta...temnumber=5645
Dial Caliper - to measure shims - $20:
http://www.harborfreight.com/cpi/cta...emnumber=40926
Once the end play is dialed in:
Bearing Packer - (not necessarily needed but helpful) - $4:
http://www.harborfreight.com/cpi/cta...temnumber=3168
My cousin had a 40 ton press so I pressed the assembly together. If you don't have access to a press you can use a spindle install tool - $35:
I think that totals $161 in special tools, or $152 if you already have a big f'n hammer
Thanks For All Of The Help It Saved Me Over 300.00 Thats Cool
This Forum Is Great
