Things That Go Bump..Posi Diff
Old Nov 2, 2004 | 01:29 PM
StylemasterZ's Avatar
StylemasterZ
Default Things That Go Bump..Posi Diff
My '74 has a 3.36 Posi-traction rear diff. When I first bought the car, I noticed a "bump" from the rear suspension when starting off, especially when turning right, like at a traffic light. Sort of like hitting a series of little pot holes in the road with the back tire. I removed as much of the rear gear oil as could with a turkey baster, put in new 90w gear oil and a container of Posi additive that I got at my local independent parts house.
Seemed to correct the problem, at leat for a time. Now it has started again. It is a bump that can be felt through the seats. It does this worse if have someone else in the car with me. And I only notice it at low speed, low RPM, just starting off from a stand still.
Is there a better oil I should be using, and is there a special posi additive that I should use. And should I have the diff checked for damage ?
Thanks all !!
Old Nov 2, 2004 | 01:37 PM
theandies's Avatar
theandies
If it went away with a gear lube change then it may be internal. Externally you should check the front Diff mounting bushing. There is a little bracket with a rubber bushing that bolts to the frame. When it goes then you hear the "bump". Thats where I'd start.
Old Nov 2, 2004 | 02:04 PM
stingr69's Avatar
stingr69
I would add an additional container of GM additive. The GM stuff is best. Then drive in a figure 8 in a vacant parking lot for a few laps and see if it goes away. I needed 2 jars in my Camaro. It would "snap" in gradual turns (ex:off-ramps) without the second jar of additive.
-Mark.
Old Nov 2, 2004 | 02:23 PM
bracketshark's Avatar
bracketshark
The GM additive is OK but I've found BFL gear lube by lakewood in the yellow labled bottle to work even better. It can be bought from JEG'S p/n 620-32970 @ 11.99 / quart. Once you put either the BFL or GM additive in, do some slow figure 8's this will get the oil in the posi unit. When driving the rotation of the ring gear and unit tend to throw the lubricant out of the clutches in the unit. Figure 8's rotate the clutches and they pick up the lubrication need to stop the poping.
Old Nov 2, 2004 | 02:37 PM
73'Vette's Avatar
73'Vette
Hmm, this sounds like the same problem I'm having. Is the GM additive available only through a dealer?
Old Nov 2, 2004 | 04:10 PM
PureSilver's Avatar
PureSilver
Dealer or some of the Corvette specialty houses (Zip's; Mid-America, Ecklers's, etc). They are all about the same price...8 bucks or so.
Old Nov 2, 2004 | 04:26 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
I had to use 2 bottles
To Things That Go Bump..Posi Diff
