Ball joint torque?
Old Nov 5, 2004 | 03:48 AM
77 vette's Avatar
77 vette
Default Ball joint torque?
Can't find this anywhere, does anyone know the torque on the two 5/16 side bolts (one is a brake stop type bolt) attaching a new lower ball joint onto the lower a-arm? I also can not find the torque value on the zerk fitting and the larger nut attaching the ball joint to the a-arm.
Old Nov 5, 2004 | 09:01 AM
VBP's Avatar
VBP
St. Jude Donor '07,'13
Upper Ball Joint: 45+
Lower Ball Joint: 75+
replacement Bolts: 25
Here is a link to our torque specs for a lot of things.
http://www.vbandp.com/instructions/torque%20specs.pdf
Tony
VBP
