Shaved Doors/Locks
Old Nov 5, 2004 | 06:23 PM
an81shark's Avatar
an81shark
Default Shaved Doors/Locks
Anyone do it? Pics
Old Nov 5, 2004 | 07:34 PM
kona's Avatar
kona
On my 80 the door handles came shaved from the factory is the 81 different?
Kona
Old Nov 5, 2004 | 10:32 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Kona
Do you have pics?
Old Nov 6, 2004 | 10:27 AM
an81shark's Avatar
an81shark
i'm talking about removing the lock and exterior handles, glass up the openings, and put in a actualtor to pop the door open with a remote.
Old Nov 6, 2004 | 02:17 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
TTT, this is interesting
Old Nov 6, 2004 | 04:28 PM
aharte's Avatar
aharte
Sounds like a good way to end up having to break a window at some point.
Old Nov 6, 2004 | 10:04 PM
74-Roadster's Avatar
74-Roadster
St. Jude Donor '06
Father & Son St. Jude Donor '09
It's a very popular mod for street rods and most users install hidden jump cables if the battery dies. The odds of both acuators breaking at the same time is slim.
Old Nov 7, 2004 | 06:08 AM
Viken's Avatar
Viken
Absolutely... : ) I'll see if I can repost some pics later. It works. It's very cool. It's kind of a lot of trouble. Some tips and comments:
1. Use a quality alarm system like one from DEI for the remote portion. Tried using a kit setup from AutoLoc and was very dissapointed in the quality (and very pricey!).
2. If the solenoids are in the door, use ones with rubber boots to keep the water out. 50lbs solenoids from AutoLoc lasted about 6 months out here in Hawaii before siezing up.
3. Now using 35lbs jobs from Watson's, which have lasted much longer, but the pull is not quite what I'd like it to be.
4. Apparently saftey checks don't like them very much.
5. Emergency button is a must, as well as exterior battery terminals.
6. Nice to get rid of the huge clunky stock latches for the smaller aftermarket parts.
7. New weather strip put quite a bit of bind on the latch, requiring a lot more pull than I expected. 35lbs solenoids seem to need a lot of help.
To Shaved Doors/Locks
