Serpintine Setup Complete, Part 2
I used the long water pump that came with the whole setup.
If im correct, all the C-3's have a short pump. I am not sure
if it's reverse. You are more than welcome to come see this in person
if you ever get a chance. I am modifiying my fan on the radiator
now. I will post more pic's later. The electric fan from the camaro
is much larger than the stock fan.. this is all the same components
I will switch over to the 406
. Thats why I did not botherto clean or paint any of the parts. I will do a big cosmetic job to
the motor and engine bay, when he is done with my block. the
main issue is pulling all the bug's, and make sure everything is
going to work. I will be so happy to have power steering again.
and the fact that i will not throw belts anymore.
http://www.thirdgen.org/newdesign/tech/serpentine.shtml
If so, there would have been no need to grind on the
A arm, and shorten the upper A arm bolt
Well son of a biscut eater, wish I knew that before
I did the grinding. Its not like it hurt anything, Just
took some time
I will put it all together and see if all goes well, I did the wiring for the alternator
last nite, I did it correctly and when i put the cable
on the battery, there is a slight hum in the alternator
I don't understand whyif the wires are the same hook up. Any idea's FEVRE
took some time
Dynamo hum?
I am not real familiar with the newer type alt so that is why I wanted to find a 2 wire plug, 50/50 chance of wiring it right. Throw in a 3rd wire and it might be problems.
wire in the back of the alt, the newer has the same set up also
I had the whole motor in my 82 GMC 4x4, blew the heads,
putting in a 454, and i put the serpintine in the vette.
Never had any noise from the pump (NEVER) I guess thats
a good thing, But it would look better without it.
Did you have to convert your power steering pump over to a metric high pressure output line? The kit comes with a PS pump with metric threads on this line.
I am converting to steeriods so I ended up cutting the f-body steering hose and taking it to a place to get a compression fitting put on it to mate with the adaptor that screws into the rack, cost $10.
it looks damn good, and blows like a tornado
its a tight fit, I only have to remove the alternator to
remove the radiator, or install it, due to the fan being
fixed to the radiator. No fan shroud, but I swear there's
no need for it now. I will put a shorter belt instead of the
delete pully, Its only common sense. I have to modd up some
upper and lower water hoses. my plumber friend is bringing
me some copper 90's 45's and straights. tonite I will finish
the job. and tomorrow I will get TT to post the rest of the pic's.
everything looks tight in the bay, but its up todate on technology
parts. GTR1999 is rebuilding my steering box now, when I
get it back on I will figure how the power steering hoses work.
If anyone already know's the issue to this chime in
hoses, I did not even think about this pump being metric
The crankshaft pully you have caught my attention. It looks a lot smaller in diameter than the pully that came with the serpentine kit from GM Performance. I'd like to have a smaller pulley to reduce alternator and PS pump rpms.
Anyhow, if anyone's interested, the PN of the smog pump delete idler pully is 10129569. Look in the GM Performance Parts catalog for the three Serpentine Kits they sell. One is just hardware: brackets, pulleys, tensioner, etc. The next kit includes, in addition, the PS pump, a reverse rotation water pump, a 104 amp alternator, and the air conditioner delete pully and smog pump delete pully. The final kit includes all of the previous plus an air conditioner compressor.
) so I decided to have him put the compression fitting on the old hose so I could give it a try.
