Serpintine Setup Complete, Part 2
Old Nov 10, 2004 | 05:45 PM
  #41
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
I take it I have to find a company that does hydralic hoses?
to do this for me.
Old Nov 10, 2004 | 06:06 PM
  #42
Twin_Turbo's Avatar
Twin_Turbo
I think commander370 does hydraulic hoses, might want to contact him.
Old Nov 11, 2004 | 11:17 AM
  #43
68/70Vette's Avatar
68/70Vette
The power steering pump that came with my GM Performance Parts Serpentine kit has a high pressure output line with metric threads. I bought a standard high pressure line hose (english) and a high pressure line hose (metric). I was going to cut them in two and join them.
I also started making calls for a custom made hose - metric at one end and english at the other. I found a power steering/hydralic shop (in Lubbock Texas?) that would do it. However the guy had a better suggestion. Apparently the sheet steel housing of the pump (also called the reservoir or the "ham can") can be removed - taking with it the metric output opening. Then you just replace it with the reservoir from an older pump that has the english output line threads. I haven't tried this. The guy who made this recommendation didn't like the idea of a custom hose. The idea being that if your out on the road and the hose fails, you won't be able to get a replacement.
Old Nov 11, 2004 | 11:37 AM
  #44
Fevre's Avatar
Fevre
That sounds like a good idea as long as the stock hose will work, I had have a custom hose for the steeriods and the steeriods hose would not work even with a change you desc because the hose fitting needed to be rotated 90 degrees.
Old Nov 11, 2004 | 05:01 PM
  #45
MEGALADON's Avatar
MEGALADON
I did not get a chance to fool with the car last nite.
I will try to get some pic's today , with the
radiator in and fan.
Old Nov 11, 2004 | 05:28 PM
  #46
markdtn's Avatar
markdtn
I have 3 suggestions for hoses:
1) Go to parts store and look at the illustrations in the back of their hose book and find what you need stock
2) Take the stock hose from the pump and the stock hose from the car and cut them in the middle. Have any hydraulic shop install a "bullnose" or flare fitting (1 male, 1 female) then you can turn them to whatever orentation you need and tighten them down.
3) Take a stock hose for the car and cut the end of the double-flare at the pump off. Remove the metric fitting from the stock pump hose and install it on the car hose. Double-flare the end and you are set. Most metric fittings on automotive p/s hose are made for standard tube diameters.
Old Nov 11, 2004 | 05:46 PM
  #47
MEGALADON's Avatar
MEGALADON
thanks Mark, all 3 were great idea's also.
Old Nov 11, 2004 | 06:14 PM
  #48
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Here is my old set up.
Old Nov 11, 2004 | 06:20 PM
  #49
MEGALADON's Avatar
MEGALADON
Budman, what upper hose are you using?
Old Nov 11, 2004 | 06:33 PM
  #50
Budman68's Avatar
Budman68
St. Jude Donor '07
That was the stock 78 hose with a adjustable t-housing.
Old Nov 11, 2004 | 06:44 PM
  #51
MEGALADON's Avatar
MEGALADON
