Nuts Bolts etc
Old Nov 8, 2004 | 06:35 PM
Bryan8412_2's Avatar
Bryan8412_2
Default Nuts Bolts etc
Now that I'm coming close to the re-assembly process I'm hating the old rusty nuts and bolts (I hate being a perfectionist )Is there a place which overs a complete nut/bolt kit for the corvette? If not, is there at least a listing online of every nut and bolt? All the special stuff I have on order already (shock mounts, camber strut rod bolt etc). Thanks!
Bry
Old Nov 8, 2004 | 06:49 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
MidAmerica, Ecklers or Corvette Central have most if not all bolts and nuts available. They are 'original' but not cheap at all, it depends on what you want, stainless or grade 8 bolts are available in all sizes, shapes and whatever at www.mcmastercarr.com
ok, you will have to measure the bolts that you want, it is less convinient...
Old Nov 8, 2004 | 07:01 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
If you don't destroy them on removal. I've had good luck replacing the bolts by taking the old ones to a hardware store and matching them up to new grade 8 bolts. Use the matching nut to make sure that the threads are the same.
Also, i think that some assembly manuals that I've seen specify the bolts as well.
The hardware store is probably cheeper than Ecklers.
Old Nov 8, 2004 | 07:03 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
I was very surprised that even Lowe's has stainless and Grade8 bolts in many sizes. Definately less expensive than Eckler's.
Old Nov 8, 2004 | 07:06 PM
Simul8's Avatar
Simul8
I purchased all my bolts from a local Bolt/Fastener distributor. Very affordable. Much cheaper than HD or Ace hardware stores. Just about everything is now stainless.
Old Nov 8, 2004 | 10:40 PM
markdtn's Avatar
markdtn
I have bought lots of bolts from Lowes. Very nice selection at reasonable prices. Grade 8 and stainless.
Old Nov 9, 2004 | 12:05 PM
ZD75blue's Avatar
ZD75blue
Ya just have to be careful with stainless... the bolt and nut have to be a perfect match, or you'll be there all day trying to get em off! (Heat expansion...) For some reason we never give it a second thought going on!
Old Nov 9, 2004 | 12:30 PM
exdrag77's Avatar
exdrag77
I've read when using stainless bolts with steel nuts or cast iron, you need to use anti sieze to make removal easier.
To Nuts Bolts etc
