Did you know?
Old Nov 11, 2004 | 10:08 AM
Joebio's Avatar
Joebio
Default Did you know?
So this morining at 4:45 AM I went out to change out my carb, I had a holley 750 that was leaking and badly corroded, installed a edelbrock 750 that is 2 months old that I bought for cheap. Everything was going great until I went to install the vacum hose onto the rear of the carb, it is a threaded hole, and I have no fittings, NAPA doesn't open for several hours.
So did you know that a male connector from your air ratchet is the exact same size? (ask me how I know) LOL
Anyway I fire it up and seems to run ok, walk to the passenger side and see what appears to be transmission fluid exiting the underneath of my car at a rapid rate!
As much as I wanted to get to it, I was out of time.
Its always something
Old Nov 11, 2004 | 10:18 AM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
Sometimes you have to improvise!
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Necessity is the mother of all inventions. Well now you have time to go to NAPA and get the correct fitting. At least you now know that the air fitting will fit.
Old Nov 11, 2004 | 10:24 AM
Joebio's Avatar
Joebio
Actually I will wait until I diagnose where all the tranny fluid is coming from, figure I will get it all in one trip!
To Did you know?
