Stroker engine
Old Nov 12, 2004 | 06:03 PM
b-line's Avatar
b-line
Default Stroker engine
I have an engine question. I am considering buying a stroker engine to replace my tired 350/270 in my 71. I have found a place in called
South State Speed Shop that has a 377 Cubic Inch SBC stroker that produces 405 HP. for $3900. It includes intake and carb (600CFM Edlebrock), Mallory HEI distributor, Flex plate. All internal are new including crank, lunatic cam (225 @ .50) Pro 67 cc heads, and aluminum intake (Stealth). Any one had dealings with this shop?
Any other comments, good or bad are appreciated.
Old Nov 12, 2004 | 06:08 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Typically a 377 is a destroked 400. I have a slightly larger destroke (388) that works great in my car.
See if the shop has any sort of warrantee, but $3900 doesn't seem too bad to me if it's complete from carb to pan
Old Nov 12, 2004 | 06:18 PM
b-line's Avatar
b-line
Default warranty
Yep, warranty is 12 months/12,000 miles.
Old Nov 12, 2004 | 06:40 PM
Gordonm's Avatar
Gordonm
Not bad but a 600 cfm carb on a 400 HP 377 sounds small to me. Make sure you are really getting what they advertise.
Old Nov 12, 2004 | 06:56 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I like the Lunatic cam , but a 600 CFM spreadbore carb on a 400 HP motor with a 4.125 bore, I don't think so, warning flags are up
Old Nov 12, 2004 | 11:28 PM
HDIronman's Avatar
HDIronman
Motor sounds like a 350 with standard bore and 3.75 crank. NOT A 400 block.
Old Nov 13, 2004 | 11:47 AM
ICEMAN59's Avatar
ICEMAN59
Yea I find that hard to believe, should be a least a 750 or 800 cfm to get that kind of HP. I have a 383 with and Edlebrock 800 cfm and a Air Gap intake,fast burn heads, headers, plus roller roker cam and will only get about 480 HP at the crank.
Old Nov 15, 2004 | 09:53 AM
b-line's Avatar
b-line
Default Stroker Engine
The 600 CFM sounded a bit small to me also. I believe you are correct, it is a 350 with a 3.75 stroke. Thanks for the advice.
Old Nov 15, 2004 | 10:18 AM
gkull's Avatar
gkull
600 cfm is plenty for a mild 4.00 X 3.750 377 ci motor. You can run a 500 hp motor on 600 cfm.
You should find out the internals of this motor. Generally you get what you pay for. to make a profit thay have to use the lessor cost rotating assemblies. But at 400 hp and being a stroker it will really make your 71 go.
Old Nov 15, 2004 | 05:05 PM
b-line's Avatar
b-line
Default stroker engine
Without being to wordy internal include the following to go along with the New prepped GM 4 bolt bolt standard bore block
Speed Pro Hyperutectic Pistons 9.5:1
Childs & Albert Rings
Fed Mogul Brgs. New Cast Steel Crankshaft w/ .125 radius
Manley Hi Volume-Hi pressure oil pump
Lunatic Cam
New Pro 67 cc Heads with stainless valves
1.5 Ratio long slot rockers
New I beam floating rods
Old Nov 15, 2004 | 05:11 PM
comp's Avatar
comp
doesn't sound to bad to me,,,Have you checked their rep.
Old Nov 15, 2004 | 05:23 PM
b-line's Avatar
b-line
well actually I was hoping someone on the Forum had used this company. How can I check them out?
Old Nov 15, 2004 | 05:32 PM
checklst's Avatar
checklst
A good place to start is the Local BBB
Old Nov 15, 2004 | 06:23 PM
redvetracr's Avatar
redvetracr
Guys do the math...a 400 block (bored .30 over) with a 3.48 stroke crank is a 377...a very GOOD combination.....
...redvetracr
Old Nov 15, 2004 | 06:27 PM
Gordonm's Avatar
Gordonm
...redvetracr
So does a 4.00 bore X 3.75 inch stroke =377 ci
Old Nov 15, 2004 | 06:34 PM
Twin_Turbo's Avatar
Twin_Turbo
yup, common mistake thinking it's a 383, that's a 4.030 bore x 3.75 stroke
Old Nov 15, 2004 | 06:58 PM
MotorHead's Avatar
MotorHead
I had to look it up and they say it is a new GM block standard bore, can't understand why a machine shop doesn't just machine one of the millions of 350 blocks out there instead of buyng a new block, just does not make sense, especially since it is not a high dollar builup.
A few things bug me and either the guy is a genius or he is been sniffing too much racing fuel. Time is money and he says the small Edelbrock carb is "blueprinted" , yea looks good to me . And he is using a Manley high volume/ high pressure oil pump for a mild street motor.
To Stroker engine
Old Nov 16, 2004 | 03:25 PM
b-line's Avatar
b-line
I did check the guy out on the BBB Web site and found no problems.
Old Nov 17, 2004 | 02:40 AM
79VetteMike's Avatar
79VetteMike
There is a company here in OKC that will sell me bare standard bore small blocks all day long. They are the one piece main seal blocks that come standard with roller cams. The roller cam is not included, but the block is set up for it. I've considered starting a stroker buildup with one of these several times. The bare 2 bolt block is like $450 and the 4 bolt is another $50-$100. By the way, he has literally tons of LS blocks and heads also. He guys bulk overstock parts from GM.
Old Nov 17, 2004 | 08:22 AM
MotorHead's Avatar
MotorHead
350 junkyard blocks are next to nothing or cheaper and the machine shop has the ability to machine the block so why would they buy new blocks ?
