Advice on Winterizing??
Old Nov 13, 2004 | 12:50 PM
Sabourin's Avatar
Sabourin
6th Gear
Default Advice on Winterizing??
Hey all,
I inherited a 69 Stingray from my father and do not know tha much about it. I have read some and am working to get more knowledgeable. I was wondering if anyone knew any good tips on winterizing. Is there anything specific I should be doing? Thanks
Steve Sabourin
Old Nov 13, 2004 | 12:53 PM
markdtn's Avatar
markdtn
Where in the country are you? Is the car to be stored indoors or out? Basically you need good antifreeze and a good cover.
Old Nov 13, 2004 | 02:00 PM
redwingvette's Avatar
redwingvette
I store mine in an unheated garage. I put gas store in the tank and fill it up. Then I place a sheet of plastic on the floor and park the car on it. I place wheel dollies under the tires so I can push it around but it is not needed. Then I start the engine and spray fogging oil in the carb until I know everything is coated and shut it off. Next, I disconnect the battery and charge it up. Finally, I cover the car with a lightweight car cover and call it done for the winter.
Old Nov 13, 2004 | 03:28 PM
terry82's Avatar
terry82
i put mouse traps next to each tire.
Old Nov 13, 2004 | 08:35 PM
marshrat99's Avatar
marshrat99
I live in NW Ohio. My advise is to start the engine every couple of weeks and let it warm up to normal operating temperatures. If the weather permits, then pull the car out of the garage just to keep the brakes loosened up. Otherwise, then fogging the engine and adding fuel stablizer is essential.
Old Nov 13, 2004 | 09:18 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Originally Posted by Sabourin
Hey all,
Steve Sabourin
i would think the first thing to do is get a repair manual and read up on everything...then change all fluids try and get it running, add fresh gas with stabilizer and sart it every couple of weeks... if you have no history on the car i would disconnect the battery on it when i left it, also as was previously said protect it from rodents and do not eat around it or store any fertizler or bird seed around it....
Old Nov 14, 2004 | 09:30 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Take a look at this thread: http://forums.corvetteforum.com/showthread.php?t=945112
To Advice on Winterizing??
