Stupid SandBlasting Question.
Old Nov 16, 2004 | 11:04 AM
70BBvert's Avatar
70BBvert
By the way, you're not using sand are you? I use either silicon carbide - steel parts or glass bead for cast iron. Both are available through a local supply house.
Jim
Oops :o I meant Aluminum Oxide - 70 grit
Old Nov 16, 2004 | 11:06 AM
Twin_Turbo's Avatar
Twin_Turbo
I use AlOx, it gives a nice layer that gives a bit of rust protection also (unless it getts wet, then it will rust again), rough surface textures make that paints and primers adhere better.
Old Nov 16, 2004 | 12:08 PM
eddievette's Avatar
eddievette
St. Jude Donor '05-'06-'07-'08
I’m blasting the control arms so that I can send them to get powder coated. I found a web site that sells the media and had the manufacturer telephone number for application questions. The manufacturer recommended the aluminum oxide 80 grit, works great.
