I have a new engine, aftermarket fuel pump, etc. and wish to leave the vapor return line off the car for simplicity's sake ('75). My engine builder said I should have no problems without it, as I have a large pump and live in a mild climate (WA). He said unless it's 110* I shouldn't see vapor lock. Well, the body's off right now and once it's back on I don't think I could get one in if I tried: so it's now or never.
Have any of you eliminated your vapor return line, and are you having problems with vapor lock?
i would leave it on. you never know where the future will find you and if you need to pass emissions (later) it will need to be there. i hate to have to do something over and once i get my body back on the frame i do not want to remove it for any ones money or stupid laws.
Are you talking about the vapor return line or the fuel return line? There are 3 lines total. The vapor return line is basically for emissions control and won't be a operating problem if you use a vented gas cap.
Edit: If you are running a electric fuel pump and it's located at the tank you won't need a fuel return line. People do seem to get in trouble with large volume fuel pumps located at the engine because of the vacuum they create on the fuel line causes the fuel to vaporize in hot weather. Vacuum will lower the vapor pressure of the fuel, so if you send it through the line under pressure the problem is gone. You would then need a fuel pressure regulator located as close to the carb as possible.
Easiest solution is to leave it there and plug it up
I replaced my fuel tank with a tank that doesn't have the return line hookup... Didn't even plug the return line because no fuel is flowing through it...
