Th 350 ?
Old Nov 14, 2004 | 01:54 PM
an81shark's Avatar
an81shark
Default Th 350 ?
Shifting problem...
what is happening
THe tranny won't shift unless the rpm's are at 3K. Last time i had a shifting problem, it was a vacuum line, so i checked them, but they are fine. SOmeone else suggested a vacuum modulator, so i swapped it out, and now its shifting even higher.
If i put in L1 at the light, and shift manually, it seems to shift ok.
Any idea's. Is the vacuum modulator adjustable.
Old Nov 14, 2004 | 02:12 PM
75 Stingray!'s Avatar
75 Stingray!
Did you check the fluid level when the car was running?
Old Nov 14, 2004 | 02:15 PM
an81shark's Avatar
an81shark
checked it earlier this week and topped it off.
i'll take anouther look in a bit
as a side note, is it suppose to puke fluid when the modulator is removed?
Old Nov 14, 2004 | 04:10 PM
galvestonVETTE's Avatar
galvestonVETTE
I had the same problem with 81 after shop rebuilt 350. The vac hose split right at the modulator and was suck'in air.
Old Nov 14, 2004 | 04:24 PM
an81shark's Avatar
an81shark
i think i'm gonna stop and get a 6ft piece of vaccum hose and by pass the metal line to see if that helps. if nothing else, it'll eliminate one thing
Old Nov 14, 2004 | 05:30 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
don't know the answer but what exactly happens when a torque converter starts to fail???
does it stop working totally or does the rpm increase/decrease before it engages???
To Th 350 ?
