Flywheel diameter ??
Old Nov 15, 2004 | 08:32 PM
Rhufus's Avatar
Rhufus
Default Flywheel diameter ??
What diameter flywheel and number of teeth on a '78 L-48?
Looking at options for a new starter.
Thanx,
Rhufus
a.k.a. Kenny
Old Nov 15, 2004 | 09:02 PM
Rhufus's Avatar
Rhufus
Anyone ...... PLEASE
Old Nov 15, 2004 | 09:52 PM
jcswm's Avatar
jcswm
The Mini starters will work on both flywheels.... Dual bolt pattern AND you can change the clock position to clear headers!!!
Old Nov 15, 2004 | 09:56 PM
Pete79L82's Avatar
Pete79L82
14" diameter 168 tooth would be stock
Old Nov 15, 2004 | 10:09 PM
Rhufus's Avatar
Rhufus
I done a search and seen where some guys have tried the 1996-2000 Chevy truck starters. Supposed to be the mini-starter.
Anyone have this experience ?
Rhufus,
a.k.a. Kenny
Old Nov 15, 2004 | 11:08 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Or the Van one will work. You will have to drill out the metric holes and install 3/8 tubing. (Easy) It will zing that motor like it's got not compression.
Old Nov 16, 2004 | 12:25 AM
Rhufus's Avatar
Rhufus
I am a little confused [ as usual ].
The '78 L-48 have metric bolts for the starter ??
Do you drill it out to the O.D. of the copper tubing?
I need a little more detailed explanation. This old fart is going senile !!
To Flywheel diameter ??
