Steering Question
Old Nov 17, 2004 | 12:31 PM
Simul8's Avatar
Simul8
Default Steering Question
With the steering box centered, is the flat part of the shaft @ 12:00?
Same for the seering column. Should the flat spot be @ 12:00?
To get everything lined up, the steering wheel is 180 out????
A picture of the ragjoint @ center would be handy.
Old Nov 17, 2004 | 01:44 PM
Jim Shea's Avatar
Jim Shea
With the gear exactly on center the flat should be at 12 o'clock. Now, when you attach the flexible coupling, the stop pins should be at 6 and 12 o'clock. The pinch bolt should be passing through the 9 o'clock position with the head pointing up. The large bolt should be at 9 o'clock the small bolt at 3 o'clock.
Old Nov 17, 2004 | 07:37 PM
Simul8's Avatar
Simul8
Thanks Jim,
I'll check it out in the am.
Old Nov 18, 2004 | 11:15 AM
Simul8's Avatar
Simul8
Found the problem, the local Vette shop gave me the wrong coupling. It is 180 from my original I removed 2 years ago. I knew it was something stupid.
Thanks again Jim.
Old Nov 18, 2004 | 03:58 PM
Jim Shea's Avatar
Jim Shea
Just out of curiosity, what flex coupling did they originally sell you? I didn't think that Saginaw made any couplings that were 180 degrees reversed. You probably could have just reversed the big and small bolt to get your steering wheel back in the right position.
Jim
To Steering Question
